Custom Mint-19.2 with Linuxcnc
  • BeagleBrainz
  • BeagleBrainz's Avatar Topic Author
  • Visitor
  • Visitor
06 Mar 2020 12:43 - 06 Mar 2020 12:58 #159323 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
RTAI 4.14.148-rtai packages for testing
  • Latest 2.8
  • Produces HTML docs as a separate package
Link to folder:
drive.google.com/open?id=1A0ZqUSJqYkwB9zZBrRxkhNyxE3CMmz-g
Download install-linuxcnc-pkg.sh, qtvcp.sh and linuxcnc linuxcnc-dev linuxcnc-doc-en linuxcnc-doc-html deb files
The matching kernel files have been included in the folder, not needed for installs using the RTAI ISOs in this thread.
The kernel packages are only for those that know 100% what they doing and are not running that particular kernel.
Uninstall existing linuxcnc packages
sudo apt-get remove linuxcnc linuxcnc-dev linuxcnc-doc-en
cd to the directory where all the files are.
Install the Linuxcnc packages, this script is tied to this version: installs linuxcnc linuxcnc-dev linuxcnc-doc-en linuxcnc-doc-html
sh install-linuxcnc-pkg.sh
To fix up and existing setup with qtvcp or to install qtvcp. If you haven't got qtvcp insatlled or don't want to install qtvcp do not run the next command:
sudo sh qtvcp.sh
Last edit: 06 Mar 2020 12:58 by BeagleBrainz.
  • BeagleBrainz
  • Visitor
  • Visitor
07 Mar 2020 09:13 - 02 Apr 2020 23:13 #159389 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 MATE
  • New 7th March 2020 14:04
  • Base image is from the 20200306 RT image
  • Linuxcnc RTAI version linuxcnc_2.8.0~pre1~rmurphy.htmldocs~1c3c94442
  • Linux Kerenl 4.14.148-rtai-amd64
  • If screen doesn't show login prompt move the mouse in circles for a few seconds
  • Login screen issue is an entropy issue that shows up with fast fast machines and/or SSDs
  • 2.8 merged into local sources 6th March 2020
  • HTML docs are now a separate package
  • /etc/linuxmint/respin-version.txt contains info regarding release
  • Gparted is not removed during install
  • Updated packages at above creation
  • pncconf will work with firmware in /lib/firmware/hm2
  • New desktop shortcut to Linuxcnc Forums
  • New desktop shortcut to first page of Linuxcnc forum thread for this iso
  • New desktop shortcut to Linuxcnc github
  • Renamed this file to respin-20200301.txt & moved to /etc/linuxmint
  • New desktop shortcut to open this file with geany
  • Removed CNC Menu item pointing to html docs & html docs removed
  • update lsb Description: Linuxcnc Powered by Linux Mint 19.2 Tina
  • ISO is now UEFI bootable
  • Moved this file to $HOME/Desktop
  • QTVCP is now included
  • Glade3.8.6 has been included
  • HTML Docs have been included and added to CNC Menu
  • $HOME/utils/bin/get_linuxcnc_build_deps.sh has been included
  • Running this script by
    sh ~/utils/bin/get_linuxcnc_build_deps.sh
  • will download and install the dependencies to build linuxcnc form source
  • JT's excellent tutorial can be found here to get sources from git and compiling
  • www.gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
Unlike other images I posted this has been created using a virgin install of Mint 19.2 on real hardware.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update
sudo apt-get dist-upgrade
Iso Image:
No longer available do not ask for access
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
Last edit: 02 Apr 2020 23:13 by BeagleBrainz. Reason: No longer available do not ask for access
  • BeagleBrainz
  • Visitor
  • Visitor
08 Mar 2020 22:09 - 02 Apr 2020 23:12 #159518 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 XFCE
  • New 8th March 2020 14:04
  • This post covers both RTAI & RT_PEEMPT versions of XFCE
  • Mint version reverted from 19.3 to 19.2 to keep inline with MATE respins
  • See previous MATE announcements for details
sudo apt-get update
Iso Image:
MD5Sum:
Last edit: 02 Apr 2020 23:12 by BeagleBrainz. Reason: No longer available do not ask for access
13 Mar 2020 09:45 - 13 Mar 2020 09:48 #159999 by billykid
Replied by billykid on topic Custom Mint-19.2 with Linuxcnc
hi I tried the iso preempt-rt version and it works normally with latency of about 32000 + 32000. only problem is the slow start. more than a minute. with the standard kernel you don't wait about 20 seconds.
these are the data of the pc
mauro
Last edit: 13 Mar 2020 09:48 by billykid.
The following user(s) said Thank You: BeagleBrainz
13 Mar 2020 10:01 #160000 by andypugh
Replied by andypugh on topic Custom Mint-19.2 with Linuxcnc
If you turn on the boot messages in grub you can see what takes the time. I often see a particular process (ethernet net connection?) waiting with a 1 minute timeout.
The following user(s) said Thank You: billykid
  • BeagleBrainz
  • Visitor
  • Visitor
13 Mar 2020 10:49 - 13 Mar 2020 11:17 #160001 by BeagleBrainz
Ok from your attachment you are running the RTAI kernel, not the RT_PREEMPT.
I mentioned that issue here forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=140#159389
And it should also be mentioned in the readme that can be opened via the shortcut on the desktop.
I've noticed that behaviour, it maybe an entropy issue, in one of the other release announcements, or maybe another thread I've talked about that behaviour and how to mitigate it. It is annoying but when testing on the machines I have available that particular kernel has the better overall latency.
I've booted up quite a few times and left various amounts of time before moving the mouse and the different lengths of time can be seen when running dmesg after login to the desktop.
The offending section can be seen here, the time from the wifi message to init done message can be shortened depending on when you start moving the mouse.
[    6.682491] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   30.273648] random: crng init done
Some discussion here unix.stackexchange.com/questions/442698/...until-crng-init-done
Last edit: 13 Mar 2020 11:17 by BeagleBrainz.
15 Mar 2020 21:56 #160349 by billykid
I installed the RT_PREEMPT version and it works perfectly, very fast to start and I configured plasmac with mesa 7i80 + thcad.
Thank you very much
Mauro
  • BeagleBrainz
  • Visitor
  • Visitor
15 Mar 2020 23:11 #160360 by BeagleBrainz
Great to hear, thanks for the feedback. If you have any suggestions to help improve things just throw them up here.
Cheers
Rob
16 Mar 2020 09:28 #160398 by mydani
Replied by mydani on topic Custom Mint-19.2 with Linuxcnc
Thanks Rob - just installed it for development purposes in an Oracle VB VM.
Worked great - and no hassle with glade installation.... :-) Thumbs up!
Regards,
Daniel
16 Mar 2020 10:28 #160407 by Clive S
Replied by Clive S on topic Custom Mint-19.2 with Linuxcnc
Perfect I have just installed this Iso Image:
RT_PREEMPT drive.google.com/open?id=1I3C2zcFRlilkjQh1HKcAKKBQS1Z_5oOU
It installed fast and without any issues It also reboots quick. The best one yet :) Thanks for all the effort that has gone into this.
The following user(s) said Thank You: bbsr_5a, BeagleBrainz
Time to create page: 0.200 seconds
