I have found this topic with interesting link for Autoleveler
forum.linuxcnc.org/38-general-linuxcnc-q...to-linuxcnc?start=10
Not tested for now but it seem to create a ngc file correctly, now is time to find a way for create equivalent file with my python code.
I think i will not be "very difficult" to calculate point but i need to find how to create file and make this working correctly is another things lool.
At this point the major problem i can see is how to take care for manage to probe a T solt table ? so any help are welcome for this mathematic problem.
The goal is to embed all the stuff inside "probe screen NG" i hope i can use other value from regular probe config but need to add (6 entry box needed for "XY start" "XY end" "XY row") or (5 entry box
r "XY start" "XY end" "XY spacing")
Br
Edit : i will think for Tslot table to add fixed value in ini file but unfortunatly i think that i'm not able to create the math stuff :
"XY first length" from machine 0 for first groove
"XY groove width"
"XY plate width"
Max size can be checked with ini file
[AXIS_X]
MIN_LIMIT = -0.11
MAX_LIMIT = 356.11
Edit 2 : this was perfect if we also can use tool setter position + dimension for prevent probing in this area
