Having joint following error on 5axiskins
27 Oct 2020 03:07 #187391 by bladekel
Hello to all,
I'm very new to 5 axis kinematics and trying to using 5axiskins in my machine.
I have a machine like XYZBC 5 axis bridge mill.
I'm attaching my ini and hal files.
I construct my emc2 with trivkins and adjust all parameters for machine which works succesfully.
But when I switched to 5axiskins I have joint following errors.
Can any body help me?
Note: In the configuration files I'm using 6 axis for simulation with the 5axisgui
27 Oct 2020 03:26 - 27 Oct 2020 03:33 #187393 by Aciera
Replied by Aciera on topic Having joint following error on 5axiskins
Hm, looks like you are missing the [KINS] section in the INI. From the sim/axis/vismac/5axis/bridgemill/5axis.ini:
[KINS]
KINEMATICS = 5axiskins
JOINTS = 6
Note that 5axiskins does not handle an A axis.
You might want to update to Version 2.8 or even the switchkins-branch to be able to switch from tivialkinematics to 5axis-TCP.
www.panix.com/~dgarrett/stuff/switchkins.html
www.panix.com/~dgarrett/stuff/s_kins_guide.txt
Also regarding bridgemill:
forum.linuxcnc.org/10-advanced-configura...is-kinematics#186285
Last edit: 27 Oct 2020 03:33 by Aciera.
The following user(s) said Thank You: bladekel
28 Oct 2020 01:23 #187513 by bladekel
Replied by bladekel on topic Having joint following error on 5axiskins
Sorry for my late reply. I was trying to solve myself to learn much more but I'm unsuccesful.
I'm using emc 2.7.14.
Do I have to update my version ?
By the way, I only need X,Y,Z,B and C axes. My machine is very similar to vismach 5 axis bridgemill
28 Oct 2020 01:35 #187514 by Aciera
If you are setting up the machine from scratch then I would certainly advise to update your version. I you had the machine running on 2.7 then updating to 2.8 will require some adjustments in the config.
28 Oct 2020 05:34 #187544 by bladekel
I have installed the debian 10 with emc 2.8 from iso image.
And I have create a new configuration with StepConf Wizard.
But I'm still getting a joint following error.
Here I attached the ini and hal files....
28 Oct 2020 05:48 - 28 Oct 2020 08:30 #187545 by Aciera
You don't have any settings for the step generator in your INI. You must have missed something in the pncconf. here is what my ini section for a joint looks like:
Last edit: 28 Oct 2020 08:30 by Aciera. Reason: Got it all wrong.
28 Oct 2020 06:05 #187546 by bladekel
Excuse me but, I have a little bit confused... You wrote pncconf but I'm using StepConf for parallel port , step-dir controller...
If I'm not wrong pncconf is for mesa boards...
28 Oct 2020 08:29 - 28 Oct 2020 08:46 #187563 by Aciera
my apologies. I'm so used to the mesa boards I totally got on the wrong track. For StepConf that is of course the output you would get.
So none of the motors work? You get a "following error" as soon as you try to jog an axis?
Maybe try to reduce the acceleration and velocity:
[JOINT_0]
TYPE = LINEAR
MAX_VELOCITY = 50
MAX_ACCELERATION = 200
MIN_LIMIT = -500
MAX_LIMIT = 500
HOME_SEARCH_VEL = 0
HOME_SEQUENCE = 0
SCALE = 59.59183673469
STEPGEN_MAXACCEL = 250
[edit]
MAX_VELOCITY is in mm per second so 500 maybe a bit excessive.
Last edit: 28 Oct 2020 08:46 by Aciera.
28 Oct 2020 09:04 #187571 by bladekel
I can jog all 5 motors without any problem...
I can run a ngc file with %10 rapid override...
If I decrease the max_velocity to 50, the machine moves very slow....
But on the other hand, If I changed the kinematics from 5axiskins to trivkins with the same configuration, I got no joint following error...
28 Oct 2020 09:19 #187576 by Aciera
Ok, I think I'm don't understand your problem correctly:
You can jog alll axis and run gcode with 10% feed override, no problem.
So are you getting the following errors when you jog axis with 5axiskins or run a gcode file in 5axis kins ?
Note that for 5axis simultaneous movements you will have to reduce your acceleration considerably (compared to trivial kinematics).
Time to create page: 0.094 seconds
