Having joint following error on 5axiskins
28 Oct 2020 09:32 #187579 by bladekel
Replied by bladekel on topic Having joint following error on 5axiskins
I think the key for my problem is explained on your last sentence, reducing the acceleration. Let me check it....
And by the way, let me explain my problem again. The misunderstood is caused because of my lack of english.
I construct my machine conguration on emc with trivial kinematics with the given parameters on my last hal and ini files that I have attached.
I can succesfully the jog all axis and run gcode with %100 feed rates.
But when I switched into the 5axis kinematics (5axiskins), I can jog with %100 feed rate but can run a program with only %10 feed rate because the joint following error.
28 Oct 2020 10:10 #187584 by Aciera
Replied by Aciera on topic Having joint following error on 5axiskins
Ah yes that is a common issue with 5axis kinematics. I'm sorry for the confusion. I'm a sloppy reader sometimes.
Time to create page: 0.079 seconds
