- Configuring LinuxCNC
- Advanced Configuration
- Servo tuning / debugging help - clarification of context….
- Jaro
- Thank you received: 9
08 Feb 2021 13:59 #198057
by Jaro
Replied by Jaro on topic Servo tuning / debugging help - clarification of context….
Good day.
I also return to the questions regarding servo tuning.
I've already spent a lot of hours on it. tooth (oscillation) at the beginning was a mechanical matter, which I removed.
however, the "axis0 f-error" curve still copies the "axis0 join-vel-cmd" curve (as seen in the previous figure).
I can't get to the baseline, the f-error as described in the instructions.
I don't know if it's in the driver settings and I don't even know what to change there.
I use this driver:
support.keba.com/cds/online/#doc/01-cde-...1-cde-cdb-cdf-AHB-en
can anyone think of something to reduce high f-error?
thank you for any advice
Jaro
I use this driver:
Jaro
- Thank you received: 1482
08 Feb 2021 14:34 #198061
Replied by Todd Zuercher on topic Servo tuning / debugging help - clarification of context….
Does adjusting the FF1 help with the velocity dependent f-error?
- Jaro
08 Feb 2021 14:38 #198062
by Jaro
Thank you, Todd.
any value of FF1, whether positive or negative, does not affect the f-error curve. I tried values from -10 to +10.
- db1981
- Thank you received: 276
08 Feb 2021 14:44 #198064
by db1981
Replied by db1981 on topic Servo tuning / debugging help - clarification of context….
can you post hal and ini files?
looks like an scaling error or some wrong hal linking
- bevins
- Thank you received: 338
08 Feb 2021 14:50 #198066
by bevins
He posted the files in the first post.
Replied by bevins on topic Servo tuning / debugging help - clarification of context….
08 Feb 2021 14:52 #198067
Comment out this line in your hal file for each axis.
net x-vel-cmd => pid.x.command-derivPlease Log in or Create an account to join the conversation.
08 Feb 2021 14:55 #198068
That and you may want to update to a more current version of Linuxcnc.
That problem is caused by a bug in PNCconf that was corrected in later versions of Linuxcnc 2.7.
- Jaro
08 Feb 2021 15:11 #198072
by Jaro
now I've 2.7.15 linuxcnc version.
Do you think, upgrade on 2.8 can eliminate this anomaly?
yes I started with PNCconf and then added the necessary functionality.
I 'll try to comment you wrote.tomorow I'll send actual config file.
- db1981
08 Feb 2021 15:13 #198074
by db1981
okay...
Your ini scaling is 10V at 35mm/s (2100mm /min) is this correct?
(motor revs/min at 10V /60 (/gear ratio) * ballscrew pitch)
08 Feb 2021 15:17 #198075
It might not make a difference, unless you regenerate your configuration. The bug was in the wizard you created your config with. And I don't know if it would be smart enough to find and remove it from your existing config. Easier just to fix it manually.
Time to create page: 0.590 seconds
