- Configuring LinuxCNC
- Advanced Configuration
- Servo tuning / debugging help - clarification of context….
- Thank you received: 5328
08 Feb 2021 21:22 #198076
This indicates a problem in the hal file.
pretty sure there is a bug in 2.7 vintage pncconf
relative to changes in the PID component
that causes this issue.
Can you post your current hal/ini files?
Replied by PCW on topic Servo tuning / debugging help - clarification of context….
Thank you, Todd.
any value of FF1, whether positive or negative, does not affect the f-error curve. I tried values from -10 to +10.
- Jaro
- Thank you received: 9
08 Feb 2021 21:44 #198080
by Jaro
Replied by Jaro on topic Servo tuning / debugging help - clarification of context….
yes I'll manualy comment: net x-vel-cmd => pid.x.command-deriv
motor have limit 2000rpm/min, gear ratio is 1:2 and ballscrew pitch is 5mm.
I tried to set max 2100mm/min like rapid speed was set in heidenain tnc 135 for this mill.
- Jaro
08 Feb 2021 22:00 #198084
by Jaro
here is the current .ini and .hal file
not cleaned yet (I played with the probe screen ....)
08 Feb 2021 22:03 #198085
This should not be commented out:
#setp pid.x.error-previous-target true
and this should be commented out:
(for all axis)
(for all axis)
- db1981
- Thank you received: 276
09 Feb 2021 10:38 #198135
by db1981
Replied by db1981 on topic Servo tuning / debugging help - clarification of context….
Then your axis scaling is wrong, with this numbers i get 83.33mm/s.
the max_velocity from each axis should be ~ the theoretical mechanical speed at max Output. (you can correct this with ff1, but normaly in an velocity controll loop this should be 1.0. )
So, if you only want 2100mm/min then [Axis]max velocity should be 35.0 and [Axis] Outputscale = 4.2 (if your servo drive is set to 10V=2000rpm), ff1 = 1.0.
Then Limit the Pid output to near your output scale for example +5 / -5 so the controller would never output more than 1000rpm. 5V becaus you will need some
headroom for the controller to correct moves at max speed.
- Jaro
09 Feb 2021 18:59 - 09 Feb 2021 21:48 #198182
by Jaro
Thanks DB.
please, can you explain me how to calculate max velocity and outputscale?
servo has 2000rpm/10V
gear ratio is 1:2 so i get 1000rpm/10V behind the transfer
balscrew pitch is 5mm
1000 x 5 / 60 = 83.33mm/sec (this is maximal theoretical velocity)
meantime i corrected MAX-VELOCITY = 16.6 (last ini file )
but how this everything I can calculate on OUTPUT_SCALE, OUTPUT_MIN_LIMIT , OUTPUT_MAX_LIMIT and MAX_OUTPUT?
please, try to explane. what is necessy to stet or change?
when I set servo 800rpm/10V (i think it is possible configure driver for that)
and set
MAX_LINEAR_VELOCITY = 33.33
(TRAJ)
MAX_VELOCITY = 33.33
(AXIS X,AXIS Y,AXIS Z)
MAX_OUTPUT = 10
OUTPUT_SCALE = 9
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
is this correct?
thanks
Jaro
and set
(TRAJ)
MAX_OUTPUT = 10
OUTPUT_SCALE = 9
is this correct?
thanks
Jaro
Last edit: 09 Feb 2021 21:48 by Jaro.
- Jaro
09 Feb 2021 19:04 - 09 Feb 2021 19:04 #198183
by Jaro
thank you very much PCW and TODD.
today I manualy comment: net x-vel-cmd => pid.x.command-deriv and
uncommented #setp pid.x.error-previous-target true.
now I can use FF1 and FF2 for F-error tuning with halscope.
thanks again
Jaro
thanks again
Jaro
Last edit: 09 Feb 2021 19:04 by Jaro.
Time to create page: 0.232 seconds
