- Configuring LinuxCNC
- Advanced Configuration
- Spindle Step/Dir servo ramp down before stop on M stop command.
- NoJo
- Thank you received: 43
No - that has remained unchanged - I tamed it down in previous tests by reducing MAX_OUTPUT to below 5 in the ini - but the inherent issue remains.
That was better before, I think?HOME ALL > C rotates to index, stops momentarily ,shoots past, oscillates, converges to index and stops. Axes all show home icon
Just to be sure I explained correctly the issue - When executing M101, I understand we should disable the C Axis mode, and are in 'normal' spindle mode, ie, M03 S1000 will now run the spindle @ 1000rpm as normal, so the C axis SHOULD NOT jog in M101 -M101 > Jog works on all axes, C does not rotate but DRO changes.
To be expected, really. Add "setp axis.c.jog-enable 0" to M101 and "setp axis.c.jog-enable 1" to M100 to fix that.
What do those added lines do? Presume the '0' disables and the '1' enables - but what is enabled/disabled? The jogging of the physical axis, or the DRO? Or both?
I would have thought the intent in M101 is that the C axis is simply disabled - no jogging of the axis or the DRO,ie, sort of a basic 2 axis lathe..
I may also not have been clear on 'Not jogging anymore' issue - NONE of the Axes physically jog anymore when a M100 is executed, so will the the line setp axis.c.jog-enable 0/1 enable jogging of the x and z axes?
M100 > C does not home but rotates to DRO setting = 270deg, rotate is very fast and oscillates about 270deg, to standstill.
That's odd.
It is starting to look like my idea for a simple way to do this wasn't very good.
I think you had something usable about 2 iterations ago, and it has got worse since?
No, not really - since where the C axis began to 'work', the oscillation has been present when entering M100.
I did not fix that, merely tamed it by limiting the PID MAX_OUTPUT, but
I still don't understand the reason for the oscillation - it is fast, so not good mechanically, and has been there from the first iterations where the C axis started to work - must be to do with the PID being unhappy with entry conditions - If we know that we should be able to fix that?
But a major issue is homing with M100 - that should work..I think one cause of the oscillation will go away if homing works -
If the axis homes , and the DRO is cleared, when the axis is enabled there is no delta between position and DRO.
The oscillation mentioned at the start of this post - after HOME-ALL is a mystery, but I am sure it is related to the PID error, and the time delay in that M100 script you last posted - when the delays time out, the PID output jumps somehow?
Also related to the oscillation - is there a possibility of error due to the index pulse width ( to short to detect 'sometimes'), or the sense of the pulse ( rising edge/falling edge)? - sort of detecting the index, going past, etc? And the MESA counters doing odd things as a result?
Not sure we should give up yet ( unless you have had enough!) - or have ideas regarding a better way..!
The DRO will no longer move, and the commanded position will stay the same.I understand we should disable the C Axis mode, and are in 'normal' spindle mode, ie, M03 S1000 will now run the spindle @ 1000rpm as normal, so the C axis SHOULD NOT jog in M101 -
M100 puts the system in joint mode to home the C axis. When the C-axis is homed the system _should_ go back in to "teleop" mode.I may also not have been clear on 'Not jogging anymore' issue - NONE of the Axes physically jog anymore when a M100 is executed, so will the the line setp axis.c.jog-enable 0/1 enable jogging of the x and z axes?
Maybe we do need to unhome the C axis to actually get that to happen?
The PID enables with a very large error, and so commands a very high velocity. Limiting PID.c.maxerror should be able to fix that without affecting normal moves, but you seem to have said that it didn't?
There is a way to make the c-axis command match the c-axis feedback. But I don't like it:
Try running in spindle mode for a little while, then turn the machine off (F2) and then on again, and then try M100.
- NoJo
I am mixing to many things in a verbose post every time and getting us both in a twist.
In summary, there are presently 3 issues:
- Jogging-
Jogging works after HOME ALL, machine is in M100 mode after HOME ALL
Then M101 - Jog XZ works, Jog C increments the DRO, C axis does not move. DRO should not increment (?)
Then M100 - JOG XZC no longer works.
Then M101 - Jog XZ works, Jog C increments the DRO, C axis does not move, as above.
This all with lines added > setp axis.c.jog-enable 0" to M101 and "setp axis.c.jog-enable 1" to M100 - Homing-
HOME ALL works - all axes go to home, C to index - BUT C goes past almost a 1/2 turn and rapidly back to index.
Thereafter, jogging as as described above.
Then, do M101 and jog C ( only DRO changes now, C disabled) to 180deg
Then do M100 - after a +-2sec delay, C moves to 180deg - NOT Home index position, ie, does not 'Home' - Oscillations-
If I make MAX_OUTPUT = 2 or less >
All Gx Cxxx Moves are clean, stable, no oscillations
The scenario in Homing above ( last two lines) caused the C axis to move to 180deg, instead of homing it, BUT that move is stable, no oscillation. So all moves are stable and clean.
HOWEVER...The HOME ALL always does as described above - C goes to index, past +-1/2 turn, and rapidly back to index
Your Call...
M100 puts the system in joint mode to home the C axis. When the C-axis is homed the system _should_ go back in to "teleop" mode. Maybe we do need to unhome the C axis to actually get that to happen?NONE of the Axes physically jog anymore when a M100 is executed, so will the the line setp axis.c.jog-enable 0/1 enable jogging of the x and z axes?
See 3 above...The PID enables with a very large error, and so commands a very high velocity. Limiting PID.c.maxerror should be able to fix that without affecting normal moves, but you seem to have said that it didn't?
This was interesting:Try running in spindle mode for a little while, then turn the machine off (F2) and then on again, and then try M100.
I set MAX_OUTPUT = 2
HOME ALL ( behaviour as in 2 above)
M101, M03 S500 ( run for maybe 5sec), then M05, F2, wait a while....F2, then M100
about a 2sec delay after M100, then the C axis unwinds ALL the turns it did in the M03 S500 period - 5sec of turns @ 500rpm..
I did not look at the C DRO value after the M05, so not sure what that was or if it had changed to a big number..
Ah, no, there is a difference between limiting the max-error (on the input to the PID) and the max-output.
You could limit max-error to (say) 5 (or 1, or less) degrees, and then a 10-turn (ie 3600 degree) error would look like a 5 degree error. So in theory you would retain all the jogging / moving responsiveness but it would not go crazy on huge offsets.
- NoJo
Ok,.....
I was kind of just doing as you said..abt 8 or so posts ago....When the oscillations were first observed,
'C_axis oscillates trying to find the 360deg position.
The command is set at 360,since C was at 360 before the M101. It looks like when the mode is entered (M100) , since the command is at a big number already, its seen as a big step change.'...etc,etc
Your suggestion then was:
You can probably calm this down by using pid.c.maxoutput, set that to 400
I will try pid.c.maxerror in the morning.
- NoJo
Set pid.c.maxerror to 10, pid.c.maxoutput to 400
All C moves are stable, EXCEPT for the usual HOME_ALL.
I Halscoped these during a HOME_ALL:
pid.c.command
pid.c.feedback
pid.c.error
and pid.c.maxerror, pid.c.maxoutput - these two remain zero during the home_all
Attached a photo of the 'scope..
But, there is something wrong in the setup...
net c-pos-cmd <= joint.2.motor-pos-cmd joint.2.motor-pos-fbFor homing to work the C-axis feedback needs to be from the encoder, but it needs to be short-circuited like this in spindle mode or there will be a following-error.
First, try
net spindle-degrees joint.2.motor-pos-fbThat should make homing a lot better-behaved. But I think it will stop the spindle mode working. (I expect an instant following-error on joint2.)
- NoJo
A 1 in maxerror - same behaviour but return to index is faster - 1 rev /hour.
Then, doing what you asked to first try -
HOME ALL homes X, and then would normally do Z and C, but dies with a joint 2 following error - does not home.
Ignoring HOME ALL on start up, I then activated the spindle on the AXIS Manual screen - this gave Joint 2 following error right away.
Please check the HAL section where I added those lines - some lines appear already, etc..Maybe I messed up.
HAL:
# AXIS C JOINT 2
setp pid.c.Pgain [JOINT_2]P
setp pid.c.Igain [JOINT_2]I
setp pid.c.Dgain [JOINT_2]D
setp pid.c.bias [JOINT_2]BIAS
setp pid.c.FF0 [JOINT_2]FF0
setp pid.c.FF1 [JOINT_2]FF1
setp pid.c.FF2 [JOINT_2]FF2
setp pid.c.deadband [JOINT_2]DEADBAND
setp pid.c.maxoutput [JOINT_2]MAX_OUTPUT
#add max_error
setp pid.c.maxerror [JOINT_2]MAX_ERROR
setp pid.c.error-previous-target true
net c-pos-cmd => pid.c.command
net spindle-revs scale.degrees.in
setp scale.degrees.gain 360
net spindle-degrees scale.degrees.out => pid.c.feedback
#Add Per Andy
net c-output pid.c.output => mux2.0.in1
net spindle-index-enable joint.2.index-enable
net spindle-index-enable pid.c.index-enable
# Here we setup to start machine in C_Axis mode
setp pid.c.enable 1
setp mux2.0.sel 1
#Change per Andy net c-pos-cmd <= joint.2.motor-pos-cmd joint.2.motor-pos-fb
net c-vel-cmd <= joint.2.vel-cmdPlease Log in or Create an account to join the conversation.
A fundamental problem that has just occurred to me is that you can't rehome an Axis while running a G-code program, and it seems pretty certain that you would want to be switching mode during a program.
By trying for a minimalist. simple system I seem to have created something complex that doesn't even work.
- NoJo
I can only thank you for all the time you spent on this, and on dragging me along, and apologise for having wasted your time!
Thanks Andy
