implement 8-tool turret on lathe
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
04 Jun 2021 19:25 #211186 by RobotMatic
implement 8-tool turret on lathe was created by RobotMatic
I need to implement a tool changer on a lathe, I already have everything wired and connected to a 7I76e table plate.
Could you guide me?
Thank you!!!
It occurs to me to do it with Classicladder.
I have :
-sensor for each tool
-forward turret sensor
-rear turret sensor
-sensor that gives me a pulse for each tool position
-turret coil (on- outside) (off inside)
-slow turn turret coil
-fast turn turret coil,
06 Jun 2021 17:52 #211375 by andypugh
Replied by andypugh on topic implement 8-tool turret on lathe
I think that CL is probably a good choice if you are confortable with Ladder logic and do not need to make any axis moves as part of the tool change (which is normally the case with a lathe)
But you might find that the "carousel" HAL component is helpful to handle the position feedback and motor control.
The following user(s) said Thank You: RobotMatic
07 Jun 2021 18:12 - 07 Jun 2021 18:14 #211455 by BigJohnT
Replied by BigJohnT on topic implement 8-tool turret on lathe
This is the hal portion of my tool change on my CHNC, it might help.
# Tool Turret Encoder Setup
net turret-encoder1 wsum.0.bit.0.in <= hm2_5i20.0.gpio.063.in_not
net turret-encoder2 wsum.0.bit.1.in <= hm2_5i20.0.gpio.061.in_not
net turret-encoder4 wsum.0.bit.2.in <= hm2_5i20.0.gpio.059.in_not
net turret-encoder8 wsum.0.bit.3.in <= hm2_5i20.0.gpio.057.in_not
# Tool Turret tool change, leave the tool prep loop in as there is no prep needed
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
#net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed
net tool-cng-req iocontrol.0.tool-change => classicladder.0.in-01
net tool-cn-done iocontrol.0.tool-changed <= classicladder.0.out-01
net tool-number iocontrol.0.tool-number => classicladder.0.s32in-00
net tool-prep-number iocontrol.0.tool-prep-number => classicladder.0.s32in-01
net tur-stop hm2_5i20.0.gpio.069.out <= classicladder.0.out-02
net tur-lift-spin hm2_5i20.0.gpio.066.out <= classicladder.0.out-03
net tur-locked hm2_5i20.0.gpio.033.in_not => classicladder.0.in-02
net enc-tool-number wsum.0.sum => classicladder.0.s32in-02
net tool-cng-timeout classicladder.0.out-04 => halui.program.stop
I attached my classicladder .clp file. Create a sample axis configuration with classicladder and put that clp file in there to view it.
JT
Last edit: 07 Jun 2021 18:14 by BigJohnT.
The following user(s) said Thank You: RobotMatic, jo_key
  • RobotMatic
  • Elite Member
  • Elite Member
08 Jun 2021 12:39 #211529 by RobotMatic
Replied by RobotMatic on topic implement 8-tool turret on lathe
Video
thanks for all the help, I will be working with this I hope to move forward to finish it. This is my first time setting up a turret. Thank you for always helping in this forum.
BigJohnT - Andypugh Thank a lot !!!!!
09 Jun 2021 00:03 #211590 by Ingo
Replied by Ingo on topic implement 8-tool turret on lathe
Hi guys, I was reading, looking for something about my Turret model (BSA 200 12/20), but as I'm nob and the first time I'm making a turret, I'm suffering a lot..., actually I was very confused. First of all, I don't know if I can take this model from you because you are different. Another thing, my 12-position turret, I use the inputs, Bit1,2,4 and 8 I know it also has Parity and stroby (I don't know what it's for, how do you use it), it still has over temperature, index and locked..., how I use all this, could someone clarify me, show me the way, because I'm using 7i76E and a 7i84 daughter (including all turret entries are on it).
Thank you very much
Ingo
14 Jul 2021 00:57 #214676 by Becksvill
Replied by Becksvill on topic implement 8-tool turret on lathe
Hey mate do you have any photos of the turret?
I have just done a toolchanger in classic ladder a few weeks ago.
You may be able to adapt my config.
  • RobotMatic
  • Elite Member
  • Elite Member
14 Jul 2021 05:10 - 14 Jul 2021 05:12 #214710 by RobotMatic
video
Last edit: 14 Jul 2021 05:12 by RobotMatic.
27 Jul 2021 20:11 #216089 by Ingo
Hello,
Follow the photos on my ATC.  Tell me something your turns only to one side and reverses the rotation to lock?
Ingo
  • RobotMatic
  • Elite Member
  • Elite Member
28 Jul 2021 11:03 - 30 Jul 2021 11:21 #216129 by RobotMatic
one direction , all Hidraulic !!     video Turrent
Last edit: 30 Jul 2021 11:21 by RobotMatic. Reason: Modific
  • RobotMatic
  • Elite Member
  • Elite Member
30 Jul 2021 12:00 - 30 Jul 2021 13:13 #216364 by RobotMatic
 I have a new problem that I can't solve. For the first time I have a turret back !!!. I have placed the scale [-] atand it works fine !!. but the margin of x machine axes in AXIS appears reversed. I am using 2.7.14 on this lathe.
is there any way to specify to linuxcnc that the turret is back ? image
https://drive.google.com/file/d/19lXtRopP46tTyrpF8nlTmI9qCyXxJ1q9/view?usp=sharing
Last edit: 30 Jul 2021 13:13 by RobotMatic.
Time to create page: 1.172 seconds
