implement 8-tool turret on lathe
01 Aug 2021 09:55 #216613
Replied by andypugh on topic implement 8-tool turret on lathe
- BigJohnT
- Thank you received: 994
01 Aug 2021 17:47 #216652
by BigJohnT
linuxcnc.org/docs/2.8/html/gui/axis.html...g_axis_in_lathe_mode
Also this is not in 2.7.
JT
Replied by BigJohnT on topic implement 8-tool turret on lathe
Actually for the Axis GUI you need both both LATHE = 1 and BACK_TOOL_LATHE = 1 in the [DISPLAY] section.I have a new problem that I can't solve. For the first time I have a turret back !!!. I have placed the scale [-] atand it works fine !!. but the margin of x machine axes in AXIS appears reversed. I am using 2.7.14 on this lathe.
is there any way to specify to linuxcnc that the turret is back ? image
JT
- RobotMatic
- Thank you received: 25
01 Aug 2021 19:33 #216657
by RobotMatic
Replied by RobotMatic on topic implement 8-tool turret on lathe
Thanks a lot!!!!.
I was reading the 2.7 documentation, I will leave it like that for now and I will update later !!!.
the X axis is fine !!. it's just visual.
I'm glad that 2.8.x has an easy solution
Thanks a lot BigJognT - andypugh !!!!!!
- joekline9
01 Aug 2021 20:00 #216659
by joekline9
Replied by joekline9 on topic implement 8-tool turret on lathe
You can put in g code file:
G10 L2 P0 R180 (Rotate around Z axis, 180 for back tool, R0 for front)
I use front and back tools in the same program with gang tooling.
Although there is a bug in 2.8 that requires a work around.
The following user(s) said Thank You: RobotMatic
02 Aug 2021 08:24 #216695
Is that bug listed in the bug tracker?Although there is a bug in 2.8 that requires a work around.
- RobotMatic
02 Aug 2021 10:48 #216708
by RobotMatic
I already have the X axis working fine.
But I noticed that the X JOG keys are reversed.
Can it be reversed? or do I have to change the direction of rotation of the motor?
Thank you!!
Thank you!!
02 Aug 2021 12:32 #216716
Is it actually wrong? Jog + should move further away from the spindle axis.
- RobotMatic
02 Aug 2021 13:14 #216723
by RobotMatic
jog-X-reversed manual movement
the x-axis works perfect, the coordinate system is now well defined. only the manual movement of jog X was reversed
- RobotMatic
02 Aug 2021 13:23 #216726
by RobotMatic
Axis and jog X coincide in their + and - signs. But the X axis moves reversed and correct in its + and - signs.
They are dissociated, both are doing well but inverted between them
remember I am using 2.7.14. !! Should I update to 2.8.2? is this necessary to fix this problem?
I'm dizzy and I don't know if I'm doing something wrong
02 Aug 2021 13:44 #216729
Are you talking about jogging from the GUI, with buttons, or with an MPG?
Time to create page: 1.413 seconds
