implement 8-tool turret on lathe
- Ingo
21 Sep 2021 19:58 #221315
by Ingo
Replied by Ingo on topic implement 8-tool turret on lathe
Guys, could someone please give me a light, I'm not able to make my ATC12 rotate with the M6, I put the tool number, ex. T3 and already starts to rotate in position. Another thing, I'm using Gmoccapy and the tool number doesn't change it's locked, after you make the change it doesn't show the current number. I've been racking my brain for a couple of weeks if anyone can give a tip I would be very grateful.
- RobotMatic
- Thank you received: 25
22 Sep 2021 17:16 #221382
by RobotMatic
Replied by RobotMatic on topic implement 8-tool turret on lathe
Hello, I am finishing making my changing table work, it is my first !!!. I thought it was fine but it was not like that. Tomorrow I'm going to fight my first final battle.
I tell you, if you want an automatic change of tools this line should not beloadusr -W hal_manualtoolchange
I leave you all my .hal code that deals with the tool change.
cambio automatico de Herramientas
net tool-preparar-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net tool-solicitud-cambio iocontrol.0.tool-change => classicladder.0.in-28
net tool-cambio-confirmado iocontrol.0.tool-changed <= classicladder.0.out-21
net tool-numero-activo iocontrol.0.tool-number => classicladder.0.s32in-00
net tool-numero-a-cambiar iocontrol.0.tool-prep-number => classicladder.0.s32in-01
I have it tested and it works perfectly fine. My problem is that the changer is hydraulic, and it does not always execute the change correctly, I am trying to make the electrical signals coincide with the hydraulic one, and I am working with the ladder code
I think your problem is that you are using manual tool change in your .hal file and in my humble opinion you shouldn't.
I apologize if I'm wrong, I try to help you
- COFHAL
- Thank you received: 62
21 Jun 2022 14:57 #245551
by COFHAL
Replied by COFHAL on topic implement 8-tool turret on lathe
Is it possible for you to share the complete configuration of your ATC?
Time to create page: 0.360 seconds
