Homing fails 2.9.0 pre0-5518
4 years 9 months ago - 4 years 9 months ago #232321 by jsskangas
Normal homing nothing special.
Homing for all joints are setup exactly same.
Example ​Joint 0 will home ok, but joint 1 will give following error.
Joints are setup correctly and if you jog them they work as they should. Can see it in youtube video.
But if you homi it it will give following error immediately.
Last edit: 4 years 9 months ago by jsskangas.
4 years 9 months ago #232326 by rodw
Replied by rodw on topic Homing fails 2.9.0 pre0-5518
V 2.9 brings with it additional homing config settings for index homing. I'm not saying they are required but please consult the homing configuration  chapter on the online docs for V 2.9
4 years 9 months ago #232333 by jsskangas
Thanks, i will look into those.
4 years 9 months ago #232334 by jsskangas
Nothing new that should affect my setup.
4 years 9 months ago #232353 by andypugh
Are you building from source or using buildbot debs?
This would be a good point to run git-bisect, if things definitely worked better with a previous version of 2.9.
The following user(s) said Thank You: jsskangas
4 years 9 months ago #232404 by jsskangas
I use builbot deb.
I was already planning to force older versions to see which version works.
