- Thank you received: 118
@rodw: Also note that the machine X and Y and inverted on the diagram. The picture on the machine show that the X axis is front-back, not the usual left-right depicted on the diagram. The whole (half) trunnion then rotate around the A axis, while the rotary table (B axis) rotate around the Y axis.... Note that it is not just the Z axis that differs between the diagram and your image in the first post. In the image the B axis rotates with the A axis while in the diagram its the other way around...
