Kinematics for XYZAB mill
3 years 10 months ago #258408 by rodw
Replied by rodw on topic Kinematics for XYZAB mill
Actually, the A axis and the spindle do  coordinated TCP moves but the movement is not coordinated on the B axis (it just uses identity)
Eg, on A xis rotations, the behaivour is correct and thats the one I modified.
Maybe something is not connected correctly. I'll have  a look at the pins later..
3 years 10 months ago #258409 by Aciera
Replied by Aciera on topic Kinematics for XYZAB mill
You jumped the gun a bit there Rod, presenting that.
Finally found the mistake that was staring me in the eye.
Here is a presentable solution that actually works for both A and B axes. So you might want to halcompile that and shoot that video again :)
File Name: xyzab_trt.comp
File Size:8.71 KB
Anyway, the other think I had was that Dy is not needed because the axes of our A and B DO actually intersect.
3 years 10 months ago #258410 by rodw
Sorry to keep posting but the problem with the B axis was there before I made my changes.
If you go back to the screen dumps of vismach on this post, the tool paths are displayed there on a purely  b axis rotation.
forum.linuxcnc.org/10-advanced-configura...mill?start=40#258349
It seems really odd to have made a mistake on just one rotating axis..
Sorry I just don't know enough on this branch of maths to help..
3 years 10 months ago - 3 years 10 months ago #258413 by Aciera
We don't want the public to laugh me off the streets, do we?
Just kidding Rod, I forgot the smiley when I wrote that you jumped the gun :)
Doesn't take much to screw up a kinematic, a 'CB' instead of a 'CA' will do.
Anyway I'll redo the pdf with the math and I'll need to have a look at the kinematics comp because I'm having issues setting the rotation point in the ini file.
[Edit]
Just to be clear, the error was in the comp I posted earlier. Nothing to do with your changes. :)
[edit2]
Also tool length offset is not implemented yet.
Last edit: 3 years 10 months ago by Aciera.
3 years 10 months ago #258415 by rodw
File Size:8.71 KB
Well the translations work but in TCP mode, I'm not sure if the axes are right. Eg to lift the spindle by 50mm while turning A & B I need to do
g0 b360 a -90 y 50
IS that expected behaviour? We might have the simple axes connected to the wrong joints.
I'll look later and redo that video.
3 years 10 months ago #258416 by Aciera
Maybe compare with the xyzac-trt and xyzbc-trt simulation configs.
Time to create page: 0.070 seconds
