- Configuring LinuxCNC
- Advanced Configuration
- Spindle Uppper and Lower Limit (Or, how to change speed step size)
- Askjerry
- Thank you received: 31
11 Jan 2023 23:27 - 11 Jan 2023 23:32 #261660
by Askjerry
Spindle Uppper and Lower Limit (Or, how to change speed step size) was created by Askjerry
I am rebuilding a Laguna IQ milling machine; when the VFD was originally set up by Laguna, instead of using a potentiometer or a 0v to 10v DC signal as I have done before, they basically have four wires labeled S0, S1, S2, and S3 connected. The S0 wire is basically just GROUND=ACTIVE so it will be tied to the SPINDLE ON pin that I assign in the stepconfig. (That's the easy part.)
Now to think about the rest of the problem... the other three wires form a binary number from 0 to 7 as follows...
S1 S2 S3
0 0 0 0 RPM (Stopped)
1 0 0 10,000
0 1 0 15,000
1 1 0 20,000
0 0 1 25,000
1 0 1 30,000
1 1 0 35,000
1 1 1 40,000
The spindle is designed for a MAX of 25,000 RPM which means that I have 4 allowable speed settings.... and this is fine... I do not need anything else for what I will be doing with this mill. (Manufacturer recommendation is 9,000 to 25,000 RPM, lower not recommended.)
Normally in the AXIS screen is a spindle stop button with a forward and reverse button on either side... and since I'm using the signal SPINDLE ON, I don't need to worry about FOR or REV... just controlling the speed. (Spindle ON will be tied to S0.)
How can I set the Spindle's initial speed to 10,000 RPM... then when the + or - is pressed have it stay between the range of 10,000 to 25,000 RPM? In G-Code I can use M3 S10000 as a starting point... no problem there... and I can look at the SPINDLE PID signal and work out something to set the outputs to one of 4 settings, 10K, 15K, 20K, or 25K. But if someone starts tapping on the + button... that is a buttload of taps to go from 10K to 15K... etc. Ideally... pressing the speed up/dn buttons would be limited to those 4 speeds only... a step size of 5K.
Can that be achieved?
Worst case... I'll make 5 buttons on my pyVCP panel... STOP, 10K, 15K, 20K, and 25K. But I would love a better solution for the AXIS screen.
Could the spindle control be removed?
Could the aforementioned 5 buttons be put in their place???
I will figure out a way to look at the SPINDLE PID or SPINDLE CMD signal and do some sort of range...
If SPINDLE CMD <1000 then off
If SPINDLE CMD >9999 and <14999 = 10K (Send a 100)
etc
etc
What suggestions do you have?
... thanks in advance.
S1 S2 S3
1 0 0 10,000
0 1 0 15,000
1 1 0 20,000
0 0 1 25,000
1 0 1 30,000
1 1 0 35,000
1 1 1 40,000
etc
etc
Last edit: 11 Jan 2023 23:32 by Askjerry.
- Thank you received: 4154
12 Jan 2023 03:43 #261673
Replied by rodw on topic Spindle Uppper and Lower Limit (Or, how to change speed step size)
Gerry, mux8 will decode your bitmap to speeds. Have a look at the MPG examples and you'll get the feel for it as they use MUX4 etc but its all the same.
lincurve should be able to decode speed ranges back to your binary value.. This should let you use the S command as normal and it will pick the closest available speed.
Sounds like it will be fun!
The following user(s) said Thank You: Askjerry
12 Jan 2023 07:51 #261699
Replied by andypugh on topic Spindle Uppper and Lower Limit (Or, how to change speed step size)
In 2.9 you can set the spindle increment size in the iNI file:
linuxcnc.org/docs/2.9/html/config/ini-co...:ini:sec:spindle-num
(5000 in your case)
Also, in [DISPLAY] set DEFAULT_SPINDLE_SPEED to 10000.
Decoding spindle speed to bits could be a bit annoying, but lincurve with the output converted to an int, and then using "bitwise" to set the IO Pins ought to work.
Or a very simple custom HAL component.
(5000 in your case)
The following user(s) said Thank You: Askjerry, rodw
- Askjerry
12 Jan 2023 12:51 #261723
by Askjerry
Replied by Askjerry on topic Spindle Uppper and Lower Limit (Or, how to change speed step size)
Excellent notes!
This weekend I will start to build out the file and see how far I get. Last night I tested the spindle successfully... so I know the signals work.
Now I need to decide if I should use computer #1 which has a MESA 7i76D or computer #2 which has dual parallel ports. I'm leaning on the parallel ports and saving the MESA for when I do the PUMA robot rebuild.
Thank you again for your quick response... I'll get the mill running, then start tweaking the INI, HAL, and the pyVCP files.
Jerry
Jerry
12 Jan 2023 14:06 #261731
Following Andy's lead, it looks like you could conver the lincurve float to an unsigned 32 with conv_float_u32
then use bitslice to break it into your 4 bits
- Askjerry
12 Jan 2023 20:13 - 12 Jan 2023 23:32 #261767
by Askjerry
I had forgotten about the INI page... a true wealth of info.
linuxcnc.org/docs/2.9/html/config/ini-co...#sub:ini:sec:display
I'll play around this weekend for sure!
I just noticed my test machine is loaded with 2.7 so I'm going to have to connect to the internet and update it.
I found the commands... and it looks like we can accomplish the spindle limitations and step size.
Last edit: 12 Jan 2023 23:32 by Askjerry.
- Askjerry
12 Jan 2023 23:55 #261775
by Askjerry
How do I get version 2.9??? All I see on the LinuxCNC page is 2.8.
LinuxCNC Uspace 2.8.4 64bit
LinuxCNC Uspace 2.8.4 32bit
LinuxCNC Uspace 2.8.4 armhf
LinuxCNC Docs English Spanish French Japanese (partial) Chinese
LinuxCNC Uspace 2.8.4 Dev
RTAI Kernel 4.19.195
LinuxCNC RTAI 2.8.4 for kernel 4.9.195
LinuxCNC uspace helper for RTAI kernel
Reformatting the hard drive with a new ISO is not out of the question...
13 Jan 2023 02:13 #261779
Ok without installing something over the top,
edit your sources.list file to point at the bookworm debs and then do a dist-upgrade
itsfoss.com/apt-get-upgrade-vs-dist-upgrade/
to get to debian bookworm
then you can just type
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev
because linuxcnc is packaged in that version of debian.
Another alternative is that one of the devs has a buildbot v2 that has 2.9 on it. Not sure where it is.
- Askjerry
13 Jan 2023 11:13 - 13 Jan 2023 11:33 #261808
by Askjerry
I'm sorry... but I am not familiar enough with the inner workings of Linux to know what you are talking about. If I attempt to do a
sudo apt-get-upgrade-vs-dist-upgrade/
Then I get : sudo: apt-get-upgrade-vs-dist-upgrade/: command not found
If I go into Synaptic Package manager and search for linuxcnc, I get two results...
f-engrave
truetype-tracer
I finally was able to add the
And the associated
Items, and reload synaptic... which promptly gave me...
So yeah... no luck... LinuxCNC is completely removed from the machine, and if there is an ISO... I'll just blow this away and start over.
f-engrave
truetype-tracer
sudo apt-key adv --keyserver hkp://keys.openpgp.org:80 --recv-key EF1B07FEE0EE663EAnd the associated
deb http://buildbot.linuxcnc.org/ wheezy base 2.9-rtai
http://buildbot.linuxcnc.org/ wheezy base 2.9-rtaiItems, and reload synaptic... which promptly gave me...
PG error: http://archive.debian.org wheezy Release: The following signatures were invalid: KEYEXPIRED 1587841717 KEYEXPIRED 1668891673 KEYEXPIRED 1557241909GPG error: http://archive.debian.org wheezy/updates Release: The following signatures were invalid: KEYEXPIRED 1668892417 KEYEXPIRED 1587841717Failed to fetch http://buildbot.linuxcnc.org/dists/wheezy/Release Unable to find expected entry 'base/source/Sources' in Release file (Wrong sources.list entry or malformed file)
Failed to fetch http://linuxcnc.org/dists/wheezy/Release Unable to find expected entry '2.9-rt/source/Sources' in Release file (Wrong sources.list entry or malformed file)
Failed to fetch http://ppa.launchpad.net/deadsnakes/ppa/ubuntu/dists/wheezy/main/source/Sources 404 Not Found [IP: 2620:2d:4000:1::3e 80]
Failed to fetch http://ppa.launchpad.net/deadsnakes/ppa/ubuntu/dists/wheezy/main/binary-i386/Packages 404 Not Found [IP: 2620:2d:4000:1::3e 80]
Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/main/source/Sources 404 Not Found [IP: 2001:67c:2564:a119::148:13 80]
Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/contrib/source/Sources 404 Not Found [IP: 2001:67c:2564:a119::148:13 80]
Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/non-free/source/Sources 404 Not Found [IP: 2001:67c:2564:a119::148:13 80]
Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/main/binary-i386/Packages 404 Not Found [IP: 2001:67c:2564:a119::148:13 80]
Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/contrib/binary-i386/Packages 404 Not Found [IP: 2001:67c:2564:a119::148:13 80]
Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/non-free/binary-i386/Packages 404 Not Found [IP: 2001:67c:2564:a119::148:13 80]
Some index files failed to download. They have been ignored, or old ones used instead.So yeah... no luck... LinuxCNC is completely removed from the machine, and if there is an ISO... I'll just blow this away and start over.
Last edit: 13 Jan 2023 11:33 by Askjerry.
- Askjerry
20 Jan 2023 17:58 - 20 Jan 2023 18:06 #262530
by Askjerry
So I just went to Chat GPT (at: beta.openai.com/playground ) and asked it...
Consider LinuxCNC
Write the code to install both lincurve and bitand into HAL.
Consider the following
00000 to 09500 = 0
09500 to 10500 = 1
10500 to 15500 = 2
15500 to 20500 = 3
20500 to 40000 = 4
Consider LinuxCNC
00000 to 09500 = 0
09500 to 10500 = 1
10500 to 15500 = 2
15500 to 20500 = 3
20500 to 40000 = 4
loadrt lincurve name=my_lincurve
addf my_lincurve servo-thread
setp my_lincurve.table 0 0 0 0 1 9500 1 2 10500 2 3 15500 3 4 20500 40000 4
loadrt bitand name=my_bitand
addf my_bitand servo-thread
setp my_bitand.in0 0
setp my_bitand.in1 7
Now I'm going downstairs to test this out... if this works it will be really impressive.
Last edit: 20 Jan 2023 18:06 by Askjerry.
Time to create page: 0.119 seconds
