Spindle Uppper and Lower Limit (Or, how to change speed step size)
26 Jan 2023 11:54 #262947 by andypugh
Lincurve would have worked, but you had the X and Y numbers swapped. X is the input, Y is the output.
But then you would also have needed to convert to integer, and then pick out the bits. with another HAL component, so the custom comp is likely to be better.
26 Jan 2023 13:11 #262956 by rodw
Yes, I've always liked how s custom component removes convoluted hal configs... improving readability and maintenance.
  • Askjerry
  • Askjerry's Avatar Topic Author
  • Elite Member
  • Elite Member
27 Jan 2023 01:43 #262985 by Askjerry
I MUCH prefer the custom routine... it does EXACTLY what I needed it to do and I KNOW how to change it if needed... that was an incredible experience for me learning how to do that. Not sure how often I'll need it... but it really opens the door to future possibilities.
Time to create page: 0.119 seconds
