homing with Phase Z encoder on MESA 7i96s
- JackRay
- Thank you received: 14
13 Dec 2024 20:05 #316603
by JackRay
homing with Phase Z encoder on MESA 7i96s was created by JackRay
Good morning, gentlemen,
I'm coming back to you because even with your advice I can't adjust my encoder. I still have my “joint 3 tracking error” problem. I've made a short video showing how the position of my encoder reacts, as soon as I touch it, I get a tracking error. on the other hand, the scale of my encoder is correct on my B axis display.
My config file are attach .
Could you help me?
Thank you
Could you help me?
Thank you
- Thank you received: 5325
13 Dec 2024 20:11 #316606
Replied by PCW on topic homing with Phase Z encoder on MESA 7i96s
Set your following error limits wide (1 inch or 25 mm)
and post a halscope plot of the following error when
you do a motion.
you do a motion.
- JackRay
13 Dec 2024 20:34 #316607
by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
my unit is degrees for a rotating axis. I don't know how to use a halscope.
13 Dec 2024 20:42 #316608
Tuning/diagnosis will be quite difficult without using halscope
- Thank you received: 7478
04 Jan 2025 14:00 #318064
Replied by tommylight on topic homing with Phase Z encoder on MESA 7i96s
@JackRay,
Did you get this sorted?
- JackRay
06 Apr 2025 08:34 #325806
by JackRay
Hello, please excuse me for the delay in replying but I have been sick.
Yes, I managed to adjust my PID but not exactly, I still have small ocillations at certain positions of my rotating B-axis.
I saw that there is an Autotune. But impossible to find any practical documentation on this program which apparently makes a PID setting automatically???
I'm looking at how to program an Autotune in python. Sending commands and retrieving data, tracking errors is quite simple with "Import Linuxcnc".
the regylge of a PID is very tedious in length. If an automatic program exists, I'm a taker.
If anyone has any information I'm interested.
Thank you
Thank you
06 Apr 2025 14:34 #325817
Unfortunately Autotune programs do no adjust the feedforward or deadzone terms so fairly useless
in real world situations.
I suspect for the best performance of a position control (stepgen or Ethercat or whatever) with an added
linear feedback device, you would need two PID loops, the local high bandwidth position loop plus a lower bandwidth
PID loop using the linear encoder feedback. This could be done in hal with two PID components with their outputs
summed.
summed.
- JackRay
08 Apr 2025 18:46 #325950
by JackRay
Yes thank you but then I have no idea how to do it .
Regards
Regards
08 Apr 2025 19:04 #325952
At the minimum you should:
Expand the ferror limits as explained above.
Learn to use halscope.
It will not really be possible to tune without using halscope
regardless of the hal setup.
- JackRay
12 Apr 2025 19:50 #326191
by JackRay
but I know how to use the halscope. I know how to read the curves, but I don't know which parameter to adjust when, for example, I have oscillations in the error.
