homing with Phase Z encoder on MESA 7i96s
30 Jun 2025 20:08 #331045 by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
Are you saying that my .ini file is misconfigured and that's why I can't detect my Z homing?
30 Jun 2025 21:10 #331049 by PCW
Did you check the home switch operation?
That is, does  joint.2.home-sw-in go true (change from red to yellow in halshow)
when you manually trip the home switch?
01 Jul 2025 17:07 #331069 by JackRay
my configuration works very well on the x,y,z axes with on/off switches. homming is all done at the same time without any problem. the problem is only on this rotary axis where i have an encoder with which i want to use the Z phase to do my homing.
01 Jul 2025 18:24 #331070 by PCW
OK, that's probably to be expected since there does not seem to be any B axis home switch
and you have setup a homing scheme that requires that switch.
If you don't have a home switch on B, and you want to home to index, you need to setup
Index-only homing:
linuxcnc.org/docs/html/config/ini-homing.html#_configuration
02 Jul 2025 07:35 - 02 Jul 2025 07:35 #331091 by JackRay
Yes, that's what I've done. My axis is configured in my .hal & .ini files with Z pulse detection on my rotary axis ( B ), which has no switch. The problem is that I can't detect my Z pulse during homing on this axis ( B ). The hardware tests you made me do comply.
On all my other axes, homing is done correctly (with switches) in accordance with the attached documentation.
Last edit: 02 Jul 2025 07:35 by JackRay.
02 Jul 2025 13:40 #331102 by PCW
Did you set HOME_SEARCH_VEL to 0 as required by Index-only homing?
Otherwise homing B will search for a home switch before searching for index.
02 Jul 2025 19:34 #331121 by JackRay
ok, I understood that, but how will my axis move if I don't give any speed? it will never detect my plus Z. I can't understand the logic ☺
02 Jul 2025 21:05 - 02 Jul 2025 22:16 #331125 by PCW
The search velocity is the speed when searching for the first
home switch actuation, the latch velocity is the velocity used
for for the actual homing switch/index move so only the latching
velocity is needed in this case.
Basically, Index-only homing is specified by setting the search
velocity to 0. (as the homing documentation specifies)
Last edit: 02 Jul 2025 22:16 by PCW.
03 Jul 2025 14:22 #331160 by JackRay
OK, thanks for the explanation, so I've set all this up correctly on my other axes with switches
I've performed the action, search velocity to 0 on my b axis with encoder. but the axis doesn't stop. it doesn't seem to find the index? still the same problem.
03 Jul 2025 15:11 #331164 by PCW
Can you:
1. Post your current hal and ini files
2. When homing B use halshow to watch joint.3.index-enable
and report it's behavior
joint.3.index-enable should get set true (yellow) when B homing starts
and get cleared at the index
Time to create page: 0.109 seconds
