homing with Phase Z encoder on MESA 7i96s
- Thank you received: 7478
03 Jul 2025 15:31 #331167
Replied by tommylight on topic homing with Phase Z encoder on MESA 7i96s
Topic separated, finally.
@JackRay,
Please refrain from tainting existing topics with unrelated content, start a new topic next time.
Thank you.
@JackRay,
Thank you.
- JackRay
- Thank you received: 14
06 Jul 2025 08:35 #331374
by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
I don't understand, I have to create another subject.
- JackRay
06 Jul 2025 09:30 #331378
by JackRay
I've just created this topic:
"homing with Phase Z encoder on MESA 7i96s".
06 Jul 2025 12:12 #331385
Continue here.
Thank you.
It was for next time, not for this one, this one is fixed already.Topic separated, finally.
... start a new topic next time.
Continue here.
Thank you.
- JackRay
07 Jul 2025 16:47 #331464
by JackRay
now it's ok, my homing works properly. Thank you very much for your help. I now need to set it up to return to my Zero machine. Is it the Homing parmeter? or Homing Offset to apply an offset?
- JackRay
18 Jul 2025 09:52 #331973
by JackRay
Hello,
After adjusting my Z-phrase for homing, I'm looking to gain some prediction on the positioning of my.
I have a 2000 puls quadrature encoder, which gives me a precision of 0.04 mm. However, I can't get within 0.15mm.
How can I get as close as possible to the maximum resolution of my encoder?
Thank you
Thank you
- Thank you received: 5325
18 Jul 2025 14:15 #331978
Replied by PCW on topic homing with Phase Z encoder on MESA 7i96s
is this a static error? ( error when not in motion )
If so and you already have as much P term as you can set while
remaining stable, you can add some I term to eliminate the static error.
If it's a dynamic error ( error when in motion ) I would have to have a
halscope plot of the error to see whats going on.
- JackRay
21 Jul 2025 17:31 #332138
by JackRay
it's a static error. But when I put “I” > 1 I get a joint tracking error.
21 Jul 2025 17:55 #332139
Can you post a halscope plot of:
1 Joint velocity
2. Joint following error
1 Joint velocity
Time to create page: 0.321 seconds
