homing with Phase Z encoder on MESA 7i96s
21 Jun 2025 16:39 #330645 by PCW
Did you check index enable?
To test whether the index hardware is working (assuming you can move the axis past
an index mark), you would:
With LinuxCNC running,  use halshow to watch the signal b-index-enable
and then with either halshow or halcmd, set b-index-enable true"
halcmd sets b-index-enable true
halshow should now show b-index-enable true
now, if you move the axis past an index mark, b-index-enable should go false.
This is how you test for correct index operation.
22 Jun 2025 20:22 #330725 by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
i do that, but never nothing
22 Jun 2025 20:49 #330726 by PCW
That points to hardware issues, are you sure:
The index wiring is correct.
The encoders actually have an index output.
23 Jun 2025 17:08 #330762 by JackRay
My wiring is good. I followed the MESA7i96s documentation. I think everything is correct.
I've tested 5 RS-422 encoders with phase A+,A-,B+,B-,Z+,Z-. Or maybe my MESA board isn't working properly. I don't know how to get out of it
23 Jun 2025 18:38 #330763 by PCW
if you:
1. Disconnect the encoder
2. Change the index input to TTL mode
(W1 left)
3. With LinuxCNC running and halshows "Watch" tab showing
    hm2_7i96s.0.encoder.00.input-index, does the state of
    hm2_7i96s.0.encoder.00.input-index change when you ground
    the IDX+ input (TB2 pin 13)?
23 Jun 2025 20:23 #330774 by JackRay
i will try that tomorow
thanks
24 Jun 2025 17:16 #330808 by JackRay
So, my signal goes to true, but doesn't return to false once the wire is removed from GND. moreover, it doesn't happen every time. sometimes it works, sometimes it doesn't?
24 Jun 2025 17:48 #330810 by PCW
Is the index input jumpered for TTL MODE? (W1 left)
Unless this is done, the results will be unpredictable.
25 Jun 2025 16:58 - 25 Jun 2025 17:14 #330867 by JackRay
I'm doing the test again today
Last edit: 25 Jun 2025 17:14 by JackRay.
25 Jun 2025 17:38 - 25 Jun 2025 17:42 #330868 by JackRay
So, when I insert the wire into pin 13, the signal is on “Fasle” and when I remove it, the signal is on “True”. Without connecting Z to GND
Last edit: 25 Jun 2025 17:42 by JackRay.
Time to create page: 0.880 seconds
