c++ compiling error
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Oct 2024 16:24 - 21 Oct 2024 16:46 #312799 by bkt
Replied by bkt on topic c++ compiling error
jungle boogie is my preferred ...
Last edit: 21 Oct 2024 16:46 by bkt.
  • bkt
  • Platinum Member
  • Platinum Member
22 Oct 2024 01:17 - 22 Oct 2024 01:19 #312827 by bkt
Hi Grotius ... THE BOSS .... (or mayight "the boss" with guitar can offended? ;))   ) ...
any how ... my suspicious is not working in these manner .... axis.sig_name think not work at all .... maybe work pin_name .... but not sure axis.classicladder.0.in-10 can be set .....
the error above:
Warning: Spoiler!
in attach sen_command.h modify for "const" error .....
File Name: send_comma...0-22-2.h
File Size:13 KB
Last edit: 22 Oct 2024 01:19 by bkt.
  • bkt
  • Platinum Member
  • Platinum Member
22 Oct 2024 01:37 #312828 by bkt
ok after check .... I use signal so do_sets_cmd is more appropriate .... any how I insert a lot of debug row ..... and all output teminate before call to rtapi ....
QString strOne = QString::fromLocal8Bit(name);
    qDebug() << Q_FUNC_INFO << "Received name =  " << strOne << "  ;";
    //rtapi_print_msg(RTAPI_MSG_DBG, "setting signal '%s'\n", name);
    /* get mutex before accessing shared data */
    rtapi_mutex_get(&(hal_data->mutex));
    qDebug() << Q_FUNC_INFO << "hal_data_mutex name =  " << strOne << "  ;";
    /* search signal list for name */
    sig = halpr_find_sig_by_name(name);
    qDebug() << Q_FUNC_INFO << "halpr_find_sig_by_name name =  " << strOne << " sig value = " << sig << "  ;";
terminal show these:
Issuing EMC_TRAJ_SET_G92 --      (  +227,+424,    +0,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,)
Issuing EMC_TRAJ_SET_ROTATION --      (  +226,+360,    +0,0.000000,)
void MainWindow::toggleBnt_hal(bool) name Toggle received  : "hal_cmd_3"
int do_sets_cmd(char*, char*) Received name =   "hal_cmd_3"   ;[color=#e74c3c] /* these is the last mark before rtapi call */[/color]
/usr/bin/linuxcnc: line 955: 135813 Segmentation fault      (core dumped) $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
task: 0 cycles, min=0.000002, max=0.012565, avg=-1.000000, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Note: Using POSIX realtime
  • bkt
  • Platinum Member
  • Platinum Member
22 Oct 2024 01:43 #312830 by bkt
in attach my ini and hal file used for test (hal is more long I stopped it at foundamental) maybe I make somethings wrong and not know it ....
File Name: inifile.ini
File Size:2 KB
File Name: myhalfile.hal
File Size:5 KB
  • bkt
  • Platinum Member
  • Platinum Member
22 Oct 2024 08:31 #312853 by bkt
hi all ... Hi Grotius ...
project complete with modification
.... after these  ..... problem was solved in few step with new c++ code for char and so (from GCC7 to GCC13) ... all other depends because not insert hal_connection(); call on mainwindows ..... any how these help me to remember what learn in the past ... Too many things to do... this way, you forget what you've learned.
@Grotius .... Yesterday you send me in right directions .... but not see it
22 Oct 2024 12:54 #312884 by Grotius
Replied by Grotius on topic c++ compiling error
Hi Bkt,
You keep on dumping the core.
Nice you have a link to your project page.
What thing should i test for you? Please one thing at a time.
  • bkt
  • Platinum Member
  • Platinum Member
22 Oct 2024 15:47 - 22 Oct 2024 15:51 #312897 by bkt
maybe bad explain .... now there are not problem. Or at least it works .... thanks a gain.
After these try to insert on cmake opcua .... little bit tortuose than  qmake ..... but quite solve .... thinks I done a repo on these. Can help somethings or my mind in future.....
Any how if you would test ... no worry ... for sure you discover somethings of worses .... I have insert "hal_connection();" on minwindows? Not remember ...
@tommilight .... p.s: solution given for compile over linuxmint22 for sure it work ... but running these post code with inifile debug level 12 i can see strange and ureal warning messages ... plus think calssicladder gui work not so good as can be ... but it works. I know andyPugh work on these in these days .... see on maling list. If woul you try by your side.... we can help
Last edit: 22 Oct 2024 15:51 by bkt.
  • Moderator
  • Moderator
22 Oct 2024 17:54 #312911 by tommylight
Replied by tommylight on topic c++ compiling error
I have never used clasicladder, but i always use Axis, PlasmaC and QtPlasmaC.
Gathering some stuff to build a mill, so might start using QtDragon or QtPyVCP, no idea when though.
Rant
Been 8 days since i got delivery of 410W solar panels, they are still inside the house...
  • bkt
  • Platinum Member
  • Platinum Member
23 Oct 2024 12:19 #312986 by bkt
I write in english in very bad manner .....
@tommy Any how until rain is quite difficult pose solar panel ..... think at your home is similar to here .... it rain from 1 month more or less with some days of sun .....  sometime I wake up and think to live in Manchester ......  .... quite sure Grotius have more sun than here. I'm italian .... think Grotius live in UK and you, think to remember live other side of Adriatic sea right? ... a peace of "nostrum mare" ....
  • Moderator
  • Moderator
23 Oct 2024 12:32 #312989 by tommylight
Grotius is i Holand, so less sun for him! :)
I am in Kosovo, so lower part of eastern Europe, should be same as middle Italy for sun.
Been quite sunny theese days, so i just threw the panels on the shop roof and did some provisional wiring to test, got about 300W at 5:45PM, so not bad. Will get another panel later. I have to anker them to something, it gets windy sometimes.
Time to create page: 0.225 seconds
