c++ compiling error
- bkt
- Thank you received: 114
19 Oct 2024 08:54 - 19 Oct 2024 09:02 #312607
by bkt
Replied by bkt on topic c++ compiling error
Thanks a lot but these is not necessary, I have not problem on these .... but now is well done so can add system folder cancel mine so everyone can build it on QT6 ...
Any how if eliminate halwidget from project problem remain ... so my attached project .... (finally I purge it and with some fortunes i see is not problem of code ... but only a compile problem .... not find perhaps) ..... github.com/bkt-it/Lcnc-test-qt6 .....
I find that problem become from no linking on iniaxis.o .... and these research suggest me somethings not work on linkages from .hh and .h file .... but not an expert ... or not so mutch to solve the situation ....
gc81@gc81-df:~$ nm -A /usr/lib/liblinuxcnc.a | grep emcAxisSetMinPositionLimit
/usr/lib/liblinuxcnc.a:iniaxis.o: U _Z26emcAxisSetMinPositionLimitid
/usr/lib/liblinuxcnc.a:inihal.o: U _Z26emcAxisSetMinPositionLimitid
gc81@gc81-df:~$ grep -r "emcAxisSetMinPositionLimit" /usr/include/linuxcnc
/usr/include/linuxcnc/emc.hh:extern int emcAxisSetMinPositionLimit(int axis, double limit);
gc81@gc81-df:~$ nm -A /usr/lib/libemc.a | grep emcAxisSetMinPositionLimit
nm: '/usr/lib/libemc.a': No such file
gc81@gc81-df:~$ nm -A /usr/lib/libemc_nml.a | grep emcAxisSetMinPositionLimit
nm: '/usr/lib/libemc_nml.a': No such file
gc81@gc81-df:~$ nm -A /usr/lib/liblinuxcnc*.a | grep emcAxisSetMinPositionLimit
gc81@gc81-df:~$ nm -A /usr/lib/lib*.a | grep emcAxisSetMinPositionLimit
nm: bltVecCmd.o: no symbols
gc81@gc81-df:~$ cd linuxcnc-source-dir
gc81@gc81-df:~/linuxcnc-source-dir$ grep -r "emcAxisSetMinPositionLimit"
grep: src/objects/emc/task/taskintf.o: binary file matches
grep: src/objects/emc/ini/inihal.o: binary file matches
grep: src/objects/emc/ini/iniaxis.o: binary file matches
src/emc/task/taskintf.cc:int emcAxisSetMinPositionLimit(int axis, double limit)
src/emc/nml_intf/emc.hh:extern int emcAxisSetMinPositionLimit(int axis, double limit);
src/emc/ini/iniaxis.cc: emcAxisSetMinPositionLimit(int axis, double limit);
src/emc/ini/iniaxis.cc: if (0 != emcAxisSetMinPositionLimit(axis, limit)) {
src/emc/ini/iniaxis.cc: rcs_print_error("bad return from emcAxisSetMinPositionLimit\n");
src/emc/ini/inihal.cc: if (0 != emcAxisSetMinPositionLimit(idx,NEW(axis_min_limit[idx]))) {
src/emc/ini/inihal.cc: rcs_print_error("check_ini_hal_items:bad return from emcAxisSetMinPositionLimit\n");
grep: bin/milltask: binary file matches
include/emc.hh:extern int emcAxisSetMinPositionLimit(int axis, double limit);
grep: lib/liblinuxcnc.a: binary file matches
Thanks a lot
Warning: Spoiler!
Thanks a lot
Last edit: 19 Oct 2024 09:02 by bkt.
- Grotius
- Thank you received: 2349
19 Oct 2024 11:41 #312618
by Grotius
Replied by Grotius on topic c++ compiling error
The following user(s) said Thank You: bkt
- bkt
19 Oct 2024 12:49 #312629
by bkt
but is not possible mixing installed version and rip-install as in the past? Your cmake point to:
my .pro file point to :
INCLUDEPATH += /usr/include/linuxcnc
INCLUDEPATH += /usr/include/linuxcnc/
INCLUDEPATH += /usr/lib
INCLUDEPATH += /usr/share/linuxcnc
INCLUDEPATH += /usr/lib/linuxcnc/modules
INCLUDEPATH += $$HOME_DIR/linuxcnc-source-dir/src/hal/utils
INCLUDEPATH+= $$HOME_DIR/Qt/Tools/QtCreator/lib/Qt/plugins/designer
INCLUDEPATH+= $$PWD/wled-designer-plugin
INCLUDEPATH+= $$PWD/Lcnc-test-qt6/resources#INCLUDEPATH += $$PWD/Lcnc-test-qt6/src/plugins/opcua/open62541
LIBS+=-L $$HOME_DIR/Qt/Tools/QtCreator/lib/Qt/plugins/designer -lhalwidgetsplugin
LIBS+= -Iinclude -I/usr/lib/linuxcnc/canterp.so
#LIBS += -L/usr/lib -lnml -llinuxcnchal -llinuxcnc -llinuxcncini -DULAPI -lposemath -Isrc/emc/rs274ngc -ltirpc #-llinuxcnc
LIBS += -Iinclude -Isrc/emc/rs274ngc -Llib -lnml -llinuxcnc -llinuxcnchal -llinuxcncini -llinuxcnchal -DULAPI -lposemath -ltirp
But I use installed version and hal command of rip-install ..... for sure something is missing .... now I've not a version to check what is needed ..... any we can exchange the mail?
Warning: Spoiler!
# Set includepaths for header files etc.
include_directories(${SRC_DIR}/../)
include_directories(${SRC_DIR}/../../)
include_directories(/home/user/linuxcnc_trajectory_planner/src)
include_directories(/home/user/linuxcnc_trajectory_planner/src/emc)
include_directories(/home/user/linuxcnc_trajectory_planner/src/emc/nml_intf)
include_directories(/home/user/linuxcnc_trajectory_planner/src/emc/motion)
include_directories(/home/user/linuxcnc_trajectory_planner/src/rtapi)
include_directories(/home/user/linuxcnc_trajectory_planner/src/libnml/nml)
include_directories(/home/user/linuxcnc_trajectory_planner/src/libnml/rcs)
include_directories(/home/user/linuxcnc_trajectory_planner/src/libnml/cms)
include_directories(/home/user/linuxcnc_trajectory_planner/src/libnml/posemath)
include_directories(/home/user/linuxcnc_trajectory_planner/src/emc/rs274ngc)
include_directories(/home/user/linuxcnc_trajectory_planner/src/emc/usr_intf/axis/extensions)
include_directories(/home/user/linuxcnc_trajectory_planner/src/hal)
Warning: Spoiler!
- bkt
19 Oct 2024 12:53 #312630
by bkt
tomorrow evening I try to check and compile .... no time to study cmake system ... but think I'm obligate in near future ....
Good Night ...Good luck.
- bkt
19 Oct 2024 16:25 #312634
by bkt
- Grotius
20 Oct 2024 05:18 #312656
by Grotius
Hi Bkt,
Ok. Good luck.
Along the way, you get used to the cmake system, you don't have to study it now.
ChatGpt can does a good job in assisting you with any modifications related to your cmakelists.txt file
In the past i also used the .pro system. But i am glad to have made the switch to the cmake system.
Keep it just here, so others can benefit.
Ok. Good luck.
- bkt
20 Oct 2024 23:19 - 20 Oct 2024 23:20 #312718
by bkt
these for sure ... no worry ... ask not for these scope.
Last edit: 20 Oct 2024 23:20 by bkt.
- bkt
21 Oct 2024 09:45 #312755
by bkt
not attach my ini and hal because ethercat i/o connect .... but for now I use demo.sim.classicladder config and I add some custom pin like:
hope these problem can solve in short timer ......
github.com/bkt-it/Lcnc-test-qt6/tree/main .... the new file with some command .... but receive alwais segmentation fault when try to press button or read in out ...... maybe some problem with too old version of get_commnd.h and send_command.h ....Hi Bkt,
net hal_cmd_1 classicladder.0.in-101 <= lcec.0.4.din-0
net hal_cmd_2 classicladder.0.in-102 <= lcec.0.4.din-1
net hal_cmd_3 classicladder.0.in-103 <= lcec.0.4.din-2
net hal_cmd_4 classicladder.0.in-104 <= lcec.0.4.din-3
net in17 classicladder.0.in-60 <= lcec.0.5.din-7
net out10 lcec.0.3.dout-0 => classicladder.0.out-10hope these problem can solve in short timer ......
- bkt
21 Oct 2024 10:17 #312758
by bkt
not understand ...... problem here near here ....
attach complete file.
void set_CL_I20_OnOff(bool pinOutValue, QString pinOutName){
//char name[] = pinOutName.toStdString().c_str();
qDebug() << Q_FUNC_INFO << "func INPUT " << pinOutValue << " & " << pinOutName << " ;";
char name[strlen(pinOutName.toStdString().c_str()) + 1]; // Make sure there's enough space
strcpy(name, pinOutName.toStdString().c_str());
qDebug() << Q_FUNC_INFO << "func INPUT -- conv " << name << " & " << pinOutValue << " ;";
if(pinOutValue == true){ char valueOn[] = "1"; do_sets_cmd(name,valueOn);}
else { char valueOff[] = "0"; do_sets_cmd(name,valueOff);}
- Grotius
21 Oct 2024 12:14 #312775
by Grotius
Hi Bkt,
Attached file compiles ok.
It sets the component name, adds a dot, adds the pin name. This total string is valid for sending.
Did not test it. But should work. -- more info click here --
Good luck BKT.
Good luck BKT.
Time to create page: 0.371 seconds
