c++ compiling error
- bkt
- Thank you received: 114
16 Oct 2024 11:48 #312279
by bkt
c++ compiling error was created by bkt
I receive these error when try to use my app written in c++ .... with c++14 linuxmint 22 and Lcnc2.10 ....
seems there are something not find (library or what else ....) but not understand what is it!! Lcnc is regular install and work .... so not understand what library need after these:
LIBS+= -Iinclude -I/usr/lib/linuxcnc/canterp.so
LIBS += -L/usr/lib -lnml -llinuxcnchal -llinuxcnc -llinuxcncini -DULAPI -lposemath -Isrc/emc/rs274ngc
/usr/lib/liblinuxcnc.a(iniaxis.o):function iniAxis(int, char const*):(.text+0x235): error: undefined reference to 'emcAxisSetMinPositionLimit(int, double)'seems there are something not find (library or what else ....) but not understand what is it!! Lcnc is regular install and work .... so not understand what library need after these:
- bkt
16 Oct 2024 12:14 - 16 Oct 2024 14:12 #312281
by bkt
Replied by bkt on topic c++ compiling error
I see now in my deb installation there is not hal_priv.h file ... is possible? I try to fin it on /usr or /share or other system folder witrh no result ... these can be? In github is present ... why not in my installation?
Last edit: 16 Oct 2024 14:12 by bkt.
- Thank you received: 2177
16 Oct 2024 13:33 #312284
Replied by Aciera on topic c++ compiling error
You don't get all the source files with a deb installation, if you want everything then you should clone the git tree and build linuxcnc on your local machine (aka RIP installation)
The following user(s) said Thank You: bkt
- bkt
16 Oct 2024 14:14 #312291
by bkt
I have the rip install too .... same as in the old machine .... I have the same situation .... these last consideration is only erroneus. I'm little bit tired ....
- Grotius
- Thank you received: 2349
16 Oct 2024 15:44 #312298
by Grotius
Replied by Grotius on topic c++ compiling error
Hi Bkt,
Can i assist you to compile your project?
If you pass me link or source to compile, i will try it for you.
Greetings Grotius.
Greetings Grotius.
- bkt
17 Oct 2024 01:32 #312341
by bkt
Hi Grotius
I try to upload on my github .... honestly first time for me. when done I advice you. real thanks
Yesterday I try to load your old repo .... maybe I forgot somethings ... but nothings ... seems equal or quite equal ..... I read again and again my old ssd without find anythigs .... but I'm tired in these period ...so maybe somethings is looses .... or for sure is looses .... if not all works.
- bkt
17 Oct 2024 07:12 - 17 Oct 2024 07:14 #312372
by bkt
these means sometings go wrong during creation of .deb packages?? or c++14 not able to find .h necessary heather?
Because iniAxis is linking to liblinuxnc.a but emcAxis..... is used as c++ code (correctly) some trouble with mixing c and c++ code? .....
/usr/lib/liblinuxcnc.a(iniaxis.o):function iniAxis(int, char const*):(.text+0x6b9): error: undefined reference to 'emcAxisSetLockingJoint(int, int)'
nm /usr/lib/liblinuxcnc.a | grep emcAxisSetLockingJoint U _Z22emcAxisSetLockingJointii
nm /usr/lib/liblinuxcnc.a | grep iniAxis 0000000000000160 T _Z7iniAxisiPKc 00000000000000c8 t _Z7iniAxisiPKc.coldthese means sometings go wrong during creation of .deb packages?? or c++14 not able to find .h necessary heather?
Last edit: 17 Oct 2024 07:14 by bkt.
- Grotius
18 Oct 2024 06:56 #312498
by Grotius
Do you have a link for me? Where to find you on github?
- bkt
19 Oct 2024 03:15 #312580
by bkt
for now these link .... github.com/bkt-it/QT6-halwidget .... so you can check .... my repo is nothing of special and anonimous .... not used to work on and for me commit and so sound like somethings of misterious .... any how today is my free day project so I try to upload a reduced version of my project without many features .... so we can concentrate on lcnc part.Hi,
- Grotius
19 Oct 2024 04:00 #312581
by Grotius
Attached .pro file compiles ok. Remove .txt extension.
Did 2 modifications.
It also compiles and runs when i start a new empty gui project and link to your plugin.
see cmakeLists.txt
see cmakeLists.txt
Time to create page: 0.144 seconds
