PCIe - No parport registered at "0x " . This is not Always an error.Continuing.
1 year 7 months ago #324243 by tommylight
the point is that Linuxcnc does not find a parallel port, it finds a port that it can use but the kernel driver defines it as serial,
Hmmm, if it works, i am sure LinuxCNC can find it as parallel port, the driver in use being serial is strange if there is actually nothing serial on the board, but from experience most of those boards do show as serial and parallel or both, despite missing serial ports.
I would aim at missing "driver in use" when the error appears...
The following user(s) said Thank You: RobotMatic
1 year 7 months ago #324247 by RobotMatic
The IRQ32 plate is the one that triggers the ALRMA
1 year 7 months ago #324248 by unknown
PCW gave a very valid solution, so that has been covered.
The driver in use covers both functions of the board, and if you look at the dependencies of the driver you'll see that the parallel part uses parallel port modules.
But that is neither here nor there, the thing is a solution has given and if you really really want a change you'll have to mention on GitHub , as that's where the changes happen. You can go on and on posting messages on the forum but it'll do SFA.
And in reality it is only a minor thing that doesn't affect the functionality. If you get no response from the Devs there's nothing to stop you from cloning the repo, editting the source file and rebuilding from source, the build procedure is very well documented in the docs. I linked to the file where the message comes from, PCW gave a solution, all the hardwork has been done. Now the ball is in your court, if you choose not to do anything,nothing will change, if you choose to get involved and not just complain something may happen.
Or you could attempt to completely rewrite the detection routine.
This is how open source projects move forward. The forums are just really for user support, code stuff usually gets done via the Devs mailing list or via GitHub. Links to these resources can be found on the Linuxcnc home page.
1 year 7 months ago #324249 by tommylight
F@king google, can not find the chip that was used as parallel port on mainboards, it was something like 665 and some other numbers...or 8255 i think, been to long, and google isn't helping at all.
1 year 7 months ago #324250 by unknown
What if you try 0xD010 ?
I think a parallel port card is basically 3 latched, buffered, 8-bit shift registers attached to a very primitive MCU.
2 bidirectional shift registers.
1 Parallel in, serial out shift register.
And a CMOS not gate on 4 pins.
Seriously dude your techno babble never ceases to amaze me.
MCS9900 Diagram
Can't link directly to datasheets but you can find it on this page.
asix.com.tw/en/product/Interface/PCIe_bridge/MCS9900
Interesting idea:
Connect one of the pins on your breakout board to a falling-edge-triggered shift register to turn one output into 8 outputs!
[/code]
Already an example of that on the wiki. Bit more involved than what you suggest.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Shift_Register_Port_Expander
1 year 7 months ago #324252 by unknown
Early versions used discrete components (think XT 74LS374 according to the tomb linked below), usually these were ISA cards, 8255 sounds about right maybe some more dedicated chips later then the Super IO chips, which actually connect via LPC bus.
en.wikipedia.org/wiki/Super_I/O .
For those interested in ancient history
ia800901.us.archive.org/26/items/f15_Par...images_processed.pdf
