PCIe - No parport registered at "0x " . This is not Always an error.Continuing.
1 year 7 months ago #324784 by tommylight
From Longdons:
Ubiuntu:
02:00.0 Parallel controller [0701]: SUNIX Co., Ltd. Multiport serial controller [1fd4:1999] (prog-if 03 [IEEE1284]) Subsystem: SUNIX Co., Ltd. Multiport serial controller [1fd4:0100] Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 13 I/O ports at e030 [size=8] I/O ports at e020 [size=8] I/O ports at e000 [size=32] Capabilities: [60] Power Management version 3 Capabilities: [68] MSI: Enable- Count=1/32 Maskable+ 64bit+ Capabilities: [80] Express Legacy Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Kernel driver in use: parport_serial Kernel modules: parport_serial
Debian:
So both show drivers and modules loaded, leading to conclude not a Linux issue.
Back to chasing bus master and other flags, although we already have instances where bus master shows and does not show with the corresponding driver/module showing and not showing.
The following user(s) said Thank You: ContinenteCNC
1 year 7 months ago #324816 by unknown
No need to guess,
sudo cat /proc/ioports
Then look for the an entry mentioning a parallel port, it's been mentioned a number of times throughout the thread
1 year 6 months ago #325539 by ContinenteCNC
I wonder if there is a way to force these Sunix cards to load parport_pc driver and module from the I/O ports address?
So it will showup in dmesg as a proper enumerated parallel port.
It would make my life easier. I wrote a bash script to automate PCI card report creation ( forum.linuxcnc.org/18-computer/54368-pci...-box?start=30#325532 ) and I have a bunch of PCI cards to test and report, and some of them are Sunix.
Do any of you guys know a way?
1 year 6 months ago #325550 by tommylight
Why?
I had two of those, both showed everything on 2 different PC's, but 1 did not show driver and kernel module on a 3'rd PC. Same card did show on 1 PC and did not show on another PC.
On the PC that did not show modules another PCI card did not show modules loaded, after showing them and working for years.
All this points to something in BIOS causing that, but i am out of luck as i can not find any more of those Sunix cards.
Here is one example of it showing modules loaded
forum.linuxcnc.org/10-advanced-configura...uing?start=20#324494
1 year 6 months ago #325562 by unknown
First thing you need to do is get the pci_id.
modinfo parport_pc
That will show you a list of PCI IDs and module parameters.
Then you can use modprobe to load partport_pc using the parameter that's required to set the address of the card.
Now whether the kernel module loads automatically for that card will depend on whether the PCI ID is a match with the driver.
If you can give me your kernel version and PCI ID of the card I can check the kernel sources and see if I can find a match. If not for the kernel you're running but one that might.
In all honesty for the headaches that a parallel port can cause a mesa 7i92 plugged into your existing breakout boards is a better solution. Latency isn't a problem, migration to a another PC is easier.
But I get that parallel port cards can be cheaper.
1 year 6 months ago #325565 by ContinenteCNC
Why?
I thought it might be something trivial to do, but if it is not, nevermind. It is marginally more convenient to find base, extended addresses and available modes (they showup in dmesg and /proc/sys/dev/parport/parport*)
And the bash script I wrote to automate reports assumes it is an enumerated port. If its not, it won't work. image missing /media/kunena/emoticons/silly.png
I tried using modprobe, setpci and some others, but linux is high in my list of "things I like doing, but I'm also bad at doing".
Time to create page: 0.328 seconds
