PCIe - No parport registered at "0x " . This is not Always an error.Continuing.
1 year 6 months ago #325577 by unknown
OK.
The Linux Kernel loads drivers based on the PCI ID, there's nothing special about it. If it sees a particular PCI ID it loads the driver that matches.
So the reason lInux will load the parport_serial is because that's what the card is reporting.
For Tommy, I replied with what might be the issue directly under your post. But without the PCI ID, end manufactures can change this usually via an eeprom or maybe some other method, there's not enough info to go on.
The following user(s) said Thank You: tommylight, ContinenteCNC
1 year 6 months ago #325578 by tommylight
1 year 6 months ago #325581 by unknown
Just gone 3pm here in Sydney.
No something interesting.
I worked on a little project using an FPGA dev board to run MESA's hostmot2 firmware. First attempt was based on the 7c81 using either SPI (raspberry pi) or EPP (best on motherboard based parallel ports). The issue with the board I used is that the EEPROM need to be changed and the headers were already soldered on.
That same hardware can also be used with the LinuxcncRIO project.
Another project I had a go at was modding the 7i90 Smart serial firmware to support 4 encoders to run on a dev board.
For my latest I've grabbed a different dev board (eeprom is correct size & bought with the headers unslodered, but this time I'll be trying a Ethernet interface, chip is same as use on the Mesa products, so no having to rewrite a driver, which requires a couple of steps, first being working out the instructions of the softcore, working how the driver talks to the chip and then how it integrates with the rest.
Some pics, 2x17 ports from breakout boards (mesa 25 pin daughter boards can be used as well) and 4 extra pins for 2 smart serial ports or extra I\O.
First off is the FPGA from aliexpress:
The Ethernet board, this is experiment only, the FPGA board sits on top, disregard the type of 2x25 headers they can be changed to suit. Should have the boards in a couple of weeks.
One of the daughter boards from the orignal project.
1 year 6 months ago #325596 by ContinenteCNC
6 AM, Tom image missing /media/kunena/emoticons/laughing.png The sun is still sleeping.
Rob, great projects you've been working on! One day I will get there.
Guys, I will be right back in one or two days. I need to assist a client "two europe diameters" away from my place.
See you!
1 year 6 months ago #325615 by andypugh
The message is something that i introduced, and it means that the parport_pc kernel driver has not found the card. However that doesn't mean that the LinuxCNC driver won't work.
github.com/LinuxCNC/linuxcnc/commit/7bd5...dedfd986fb84f6a9c4a6
It's not easy to know what to do in this scenario. There needs to be some indication that there is not _necessarily_ a parport at the give address (but, also, there might be...)
1 year 6 months ago #325622 by PCW
Rather than a pop-up error message, it seems this would better be just a message
in the log, so if you are trying to debug a parallel port issue, you get notified, but you don't
have a constant nuisance alarm when things are OK.
Time to create page: 0.350 seconds
