PCIe - No parport registered at "0x " . This is not Always an error.Continuing.
1 year 6 months ago #325566 by ContinenteCNC
First thing you need to do is get the pci_id.
modinfo parport_pc That will show you a list of PCI IDs and module parameters. Then you can use modprobe to load partport_pc using the parameter that's required to set the address of the card. Now whether the kernel module loads automatically for that card will depend on whether the PCI ID is a match with the driver. If you can give me your kernel version and PCI ID of the card I can check the kernel sources and see if I can find a match. If not for the kernel you're running but one that might. In all honesty for the headaches that a parallel port can cause a mesa 7i92 plugged into your existing breakout boards is a better solution. Latency isn't a problem, migration to a another PC is easier. But I get that parallel port cards can be cheaper.
I love mesa cards, but unfortunately I can only use them in high end projects. Things get expensive really fast bellow equator line. image missing /media/kunena/emoticons/sideways.png
I believe I have attached everthing you've asked. Let me know if you need some more info. Thanks!
1 year 6 months ago #325567 by tommylight
I am more interested in finding what is causing them to show on one PC and not show on the other PC, and i am sure it is not in software as i tried two installs on the same PC with the same card and it did not show on both.
I am also sure that same PC has marginal BIOS battery as it did show "load setup defaults and continue" more than once lately.
The following user(s) said Thank You: ContinenteCNC
1 year 6 months ago #325568 by ContinenteCNC
That would be great!
I don't know if it helps, but if so I can install 2 Sunix cards (one PCI and one PCIe) and share with you a anydesk login.
1 year 6 months ago #325571 by unknown
Just as I thought it's a kernel version thing.
PCI ID 1fd4-1999 is only supported from 5.4 up
The driver is acually parport_serial.
Good info here, linux-hardware.org/?id=pci:1fd4-1999-1fd4-0100
That's why the PCI ID the most important bit of info.
You an Aussie as well ?
1 year 6 months ago #325573 by tommylight
1 year 6 months ago #325574 by ContinenteCNC
hmm, interesting finding.
Why does it use parport_serial if it is only a single parallel port with no serial ports? Or it has nothing to do?
What do you suggest as next step? Update linuxcnc to 2.9 or just the kernel?
(By the way, I am not an Aussie, I am Brazilian... Just 180 degrees apart xD)
