Retrofitting a 1986 Maho MH400E
7 years 5 months ago - 7 years 5 months ago #134495 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Thanks!
Sorry for another dumb question, but where can I find a listing of the hal names of keys on a computer keyboard?
I've been looking for options in the gmoccapy section of the documentation without much luck.
Or does the key have to be a virtual key in the interface?
EDIT: this is regarding the [button of your choice]
Last edit: 7 years 5 months ago by Glemigobles.
7 years 5 months ago #134496 by RotarySMP
I have no idea of how you assign an ascii code to a hal pin sorry. I just found this though. Looks like your need some Python.
forum.linuxcnc.org/49-basic-configuratio...ystroke-as-a-hal-pin
The following user(s) said Thank You: Glemigobles
7 years 5 months ago #134497 by RotarySMP
Since you still have the Maho pendant attached, why not just connect a pendant physical key to a mesa pin through to the hydraulic pump pin output.
7 years 5 months ago #134498 by Glemigobles
Thanks, I'll try adding to a gmoccapy virtual button first, like one of the horizontal ones. Will it stay the same across the various menus (manual mode, MDI, auto)?
7 years 5 months ago #134499 by RotarySMP
I should be continuing with the MAHO tuning, but my probe stylus arrived, so I felt like turning the adapter for it.
7 years 5 months ago #134500 by Glemigobles
Re: the pendant, I can't get into the 7i73 manual atm. I'm really burnt out by all this work and spindle crash, I'm looking to get anything just up and running so that I know where I am.
Setting up the hardware interface is going to take me 2 days at least, considering my overall level of knowledge. Maybe more, if I start thinking about optimal configurations using the Philips F keys, for example.
Right now I'm working using the same wireless keyboard I've had throughout this retrofit, it's mounted on the panel along with the display.
Time to create page: 0.397 seconds
