- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
7 years 4 months ago #135954
by RotarySMP
That shouldn't be a show stopper. Speeders are just planetary gearboxes, so all of them are going to require a feature like that to prevent rotation of the main body.
- J Green
- Thank you received: 24
7 years 4 months ago #135958
by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Think Mark is correct about end of the taper question. Can the end be removed and replaced with a pull stud ? My tired eyes thinks it may be integral an thus intended for a threaded drawbar use..
www.practicalmachinist.com/vb/dmg-mori-g...1-conversion-220395/
Hope this may help and not just add more confusion.
The following user(s) said Thank You: Glemigobles
- Glemigobles
- Thank you received: 18
7 years 4 months ago #135963
by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Thanks Bob, I've read a lot of old threads over on PM on the subject today. One guy said he simply cut off the cylinder at end of the taper and then screwed in a retention knob in it's place (there's a matching internal thread in the toolholder).
There's going to be a feature on all speeders, true, but I think some models don't have it protruding upwards (Henninger brand I think has it going sideways). If I have to both modify the toolholder and then it will only work with an extended quill then I don't think it's cheap enough
Maybe it's worth waiting a while and ordering a new one that's made to fit my application to begin with. Dunno, just really wanted this to be a great match for my plans, but the Maho is already very much a project in my case and I need to balance it out with the business side and life in general
- RotarySMP
7 years 4 months ago #135966
by RotarySMP
- RotarySMP
7 years 4 months ago #135969
by RotarySMP
If you look at it closely, it looks like that anti rotation feature is only bolted to the side of the main housing. You could probably remove it and make a new one which fit the MAHO better.
- Glemigobles
7 years 4 months ago #135972
by Glemigobles
This is probably a really stupid question, but I was wondering about that pull stud, how do you go about screwing and unscrewing it? It looks like it's round and doesn't have any design features where you could fit a key or wrench, unlike the OTT pull studs for the Maho spindle. Is it that it doesn't need to be tightly fastened?
You might succeed in selling me on this idea after all
Time to create page: 1.458 seconds
