Retrofitting a 1986 Maho MH400E
6 years 11 months ago #150177 by RotarySMP
OT - yesterday I decided to do a video review of my power scraper, as there is next to nothing about the Coborn on the web. Just one thread on Practical Machinist
Given that this is S/N 1817, they are probably pretty rare beasts.
Mark
The following user(s) said Thank You: J Green, Glemigobles
6 years 11 months ago #150178 by chris mcm
Replied by chris mcm on topic Retrofitting a 1986 Maho MH400E
I will have to wait for Brad to confirm. He is busy with other commitments. I am again using the Maho but it would be nice to have the D.R.O. working. The other TNC features I have never used. I don't believe they have ever worked since I owned the machine.
At this stage, am I better to start the retrofit (as done by Mark) rather than waste time and more money on the Heidenhain TNC 135. As I see it any obsolete spares are going to be second hand or if off the shelf thirty years old. I see this as an ever continuing problem. Re Marks last message. I / We can start the retrofit and keep the machine running as a manual Milling Machine. Do I really need a CNC milling machine?. At my age maybe not. I have learn't some Auto-cad in the past. I am interested and the proposed system will be more reliable.
Using the machine today reminds me of some past problems I had experienced with the Maho.
The control console is too far away from the spindle. This makes setting up the work central to the spindle difficult. When tool changing it is difficult to hold a heavy facing cutter and operate the tool change switch. May be OK for a young person but I find it hard. Seems a control pendant would be helpful. I don't see it listed as a Maho optional extra. I can't believe the Maho designers got this wrong. Maybe it is the way I am using the machine.
One more thing. When using the power feed you press the direction and then the black button on the lower right of the Maho controls.
My question, how can you change direction of the feed (side ways) without stopping the spindle?.
Again, Thank you all for your help getting this fine example of German Engineering going again.
Cheers Chris
6 years 11 months ago - 6 years 11 months ago #150179 by RotarySMP
So do you only ever use it for cutting in straight lines, one axis at a time? You don't have to learn Autocad to use more of the functionality of a CNC machine. For simple jobs, I'll often start with a sketch, and peice of paper and write the Gcode program by hand. Being able to use G2/3 to cut curves and helix is already quite a step up from a manual machine. From there you can learn the canned cycles like peck drilling which also greatly improve the usablity. I'm not sure what the canned cycles in the TNC are, but the Phillips 432 had a very good reputation for used friendly and comprehensive cycles. The LinuxCNC equivilent is the NativeCAM plug in.
Would it be expected that the DRO indications should work without the TNC up an running? I doubt that, but am just guessing. It would seem there is no reason to doubt the function of the encoders, it is just that no-one is reading them as the TNC is down.
On my MAHO, there is a provision to add a foot switch for the hydraulic tool release. I couldn't find this in your schematics, but you could just add it in parallel with the existing hydraulic tool release button.
Basically just add a switch between pins 265 and 142. Something like this Industrial foot switch
If you retrofit this, you will have some things to deal with which I didn't have to. For example, I didn't have to give LinuxCNC control over axis brakes. The MH400E only has one of Z, and it's release is hardwired. LinuxCNC can do this (it can do just about anything), but you do have to get down and dirty with learning some new skills. If you really just want to use it as a manual machine with a DRO, try and get the TNC working, and keep it working.
Mark
Last edit: 6 years 11 months ago by RotarySMP.
6 years 11 months ago #150189 by RotarySMP
Hanno posted his MH400C project on CNCEcke.
www.cncecke.de/forum/showthread.php?1020...ideal-f%FCr-Retrofit
€1100 for this four axis machine, including a bunch of tool holders is a steal. That cable salad looks wild, but it was systematically disconnected, and numbered. The original control cabinet is there, including both indramats, the Siemens SImoreg for the Variable speed DC main spindle (like a MH400E2) , central lube unit, hydraulic unit, manuals, wiring diagrams, encoders ballscrews, housing, control module are all there. It was put out of sevice for a failed EXE. You can get 4x 602 EXE's off ebay for about €250 put the original electrical cabinet back together with LinuxCNC and have an excellent mill. Looks daunting, but is actually way less work than converting a manual mill, and has the iron quality to really perform.
It is on a pallet, with a forklift available.
This is as close as you get to a perfect home shop CNC project.
6 years 11 months ago #150209 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
A quick note about the VGA converter, it was my understanding from doing online research at the time of buying the XVGA box that the signal in my machine was not just CGA. I did investigate the retro-video-game route but for the life of me I no longer remember why I decided against it. Maybe I got some clues from the TV repair guys who tried to fix my fried CRT display, I did talk to them about the type of signal and they seemed knowledgeable in that regard.
Great to hear about the Maho up and running Chris! Even if there's no CNC, it's better to have a useable machine than no machine :)
Mark, maybe you would consider lending me your power scraper for its selling price next year when I get to work on rebuilding my MH600 :)
The speed advantage vs manual scraping in your video somehow made me think :)
6 years 11 months ago #150210 by RotarySMP
The scraper mostly lurks in a corner under my bench. I am sure we can come to an arrangement once you get into scraping your MAHO.
Mark
The following user(s) said Thank You: Glemigobles
Time to create page: 2.864 seconds
