- Thank you received: 276
Retrofitting a 1986 Maho MH400E
- db1981
6 years 11 months ago #150122
by db1981
Replied by db1981 on topic Retrofitting a 1986 Maho MH400E
the 29Volt is a bit to high, but not the cause of the problem.
The Machine was built for 380/220V.
I believe Brad measured them without e-stop switched on, so this is the Voltage without any load.
I remind that the big transformer in the back has other windings for higher main voltages, so they can switch them.
- fixer
6 years 11 months ago - 6 years 11 months ago #150139
by fixer
Replied by fixer on topic Retrofitting a 1986 Maho MH400E
[strike]Did you press CE button after stromunterbrechung?[/strike]
sorry, type too quick, read too slow (:
If you need some parts for tnc I could probably find some... I am from middle EU.
Last edit: 6 years 11 months ago by fixer.
- BradMck
6 years 11 months ago #150145
by BradMck
Replied by BradMck on topic Retrofitting a 1986 Maho MH400E
Hi All,
I have already had the TNC to my electronics serviceman, He has replaced capacitors and found the 5V Rail was down to 4.75V, he has fitted an external 5V supply to the internal 5V Rail.
The TNC would not complete the startup sequence while it was being bench tested without the Maho Connected to it.
Brad
Brad
- db1981
6 years 11 months ago #150153
by db1981
Hi Brad,
this sounds like bad eproms to me, but chris wrote that the eproms are already exchanged....
Did you have an look on the service manual from the tnc.
In this you will find test routines for the single boards, and description of the leds.
- J Green
- Thank you received: 24
6 years 11 months ago - 6 years 11 months ago #150155
by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Brad
I was wondering if the external 5 volt supply is a switching or a linear type power supply?
While the TNC is on the bench , could someone check
-- the sweep frequency --- video signal levels that go to the video monitor ? Would be useful if the monitor is up graded to a LCD type.
-- the voltage going to the LS 403 scales from the TNC X-Y Z connectors. Think pin 4 =Com an pin 3 =+ 5 volt DC , Please ask Mark or db1981 to check which pins as I may not remember correctly.
Any thought of while at the bench to emulate some of the MAHO signals to see if the TNC will progress further thru the boot up sequence ? db1981 has provided a digram of the signals .
During the MAHO down time, any thoughts on replacing the old DC caps ___ in the Indromat 3 TRM 2 _ the MAHO 24 volt DC supply? _ the monitor?
Remember that back in the 1970s or 1980s IC chip manufactures tried using aluminium bonding wire vers gold , what a disaster that became. Could the replacement eproms be New Old Stock with that bonding wire mess up?
Last edit: 6 years 11 months ago by J Green. Reason: Added almuinum bonding wire thought
- db1981
6 years 11 months ago #150156
by db1981
The tnc has to startup with a Text Message , only with power connected .
There are 2 x 5V rails, arme they both checked ?
The following user(s) said Thank You: J Green
Time to create page: 6.035 seconds
