- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
6 years 9 months ago - 6 years 9 months ago #156099
by RotarySMP
I am not going to replace that elbow any time soon. Just clean it out 1x year.
I uploaded the video of installing the LED ring light which Hanno graciously donated to the cause... Thanks Hanno, it is much appreciated.
Mark
Mark
Last edit: 6 years 9 months ago by RotarySMP.
- hanmon
- Thank you received: 23
6 years 9 months ago #156144
by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Hi Mark,
WOW !
I didn't expect THAT !!!!!
My personal, professional unboxing video
There are a few things that can be improved with this construction.
I should have provided the LED-ring with a plug for easy removal. As I do not have any device that needs the anti-rotation mounting it was of no concern for me.
Plus the light color is really cold, which needs getting used to.
I have wired it to permanent 24V, 204 if I remember correctly.
I can provide the drawing, G-Code and Dimensions for the LED-ring that is available on ebay and aliexpress if someone wants to copy it.
Cheers
WOW !
Cheers
- Clive S
- Thank you received: 486
6 years 9 months ago #156157
by Clive S
How about mounting the light ring with a male-female stud then you won't have to remove it for the tapping attachment .
Nice job by the way:)
Replied by Clive S on topic Retrofitting a 1986 Maho MH400E
- RotarySMP
6 years 8 months ago #156900
by RotarySMP
Thanks Clive.
I did some machining on the mini-lathe bed, and posted that into episode three of that build...
I measured the table before mounting the bed, and it was quite badly out of alignment. Loosened the table mount bolts and tweaked it back level in X. It leans forward a far bit in Y. Another scraping job on the horizon? Although I have also never checked the adjustment of the gibs either.
Setting up to machine the lathe feet was difficult, as they were too far apart to mill in one set up. The result was not great with nearly 60µm slope and variation.
Setting up to machine the tail stock clamping surface went better. Took about an hour and a search for my box of various shim stock, to get it close. I couldnt get it closer than about 15µm over 400mm. Was pretty happy with the result. It used to drive me nuts that the lever tail stock locking was always too loose or too tight. Given 0.8mm variation, that was no wonder.
Mark
Mark
The following user(s) said Thank You: J Green
- J Green
- Thank you received: 24
6 years 8 months ago #156901
by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
This is just great ---- Machining with the MAHO
Thanks Mark !
A great way to end the weekend , now if only age challenged Tony could share his material cutting skill.
Hanmon There is room here for you
What is happening in your neck of the woods ? Thought your LED Lighting is just Peachie
Bob
Thanks Mark !
Bob
- RotarySMP
6 years 8 months ago #156902
by RotarySMP
Did you notice that I screwed up the program to cut the vee block? I typo'ed a G01 to a G0, so it only ran the first pass at the desired F450, and then ran all the other passes at F2500. Lucky the $10 chinese end mill was cooperative.
Did you guys watch Edge precision's latest video?
When he gouged the work with an erroneous plunge from the dove tail cutter, I felt like less of an idiot for all the cutters I have wrecked so far.
Mark
Mark
Moderators: piasdom
Time to create page: 0.191 seconds
