Retrofitting a 1986 Maho MH400E
6 years 7 months ago #159943 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
I thing it will work, disconnect the (gearbox) motors and check while you make the first attempt so you wont crush the gearbox.
6 years 7 months ago #160201 by RotarySMP
There is also a Simulator in github, so you should first run changes to the gearbox comp through that ti test them.
Mark
6 years 6 months ago #164160 by RotarySMP
I wrote a short program (attached) to surface and trim the end of piece of stock, but made a typo in the fourth to last line.
o100 endwhile
instead of
o110 endwhile
When I tried to load the file, LinuxCNC tried to verify it, and got in an infinite loop. Is there are more elegant way to recover from this than hard rebooting the machine?
Mark
6 years 6 months ago #164169 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
RotarySMP wrote: When I tried to load the file, LinuxCNC tried to verify it, and got in an infinite loop. Is there are more elegant way to recover from this than hard rebooting the machine?
Mark
"Esc" should work, but may take a while.
6 years 6 months ago #164190 by RotarySMP
I just did it again. This time again a conditional loop:
C = -1
while [x GT Y]
x = [x-C]
So the thing looks until a number drops below another one, but it starts higher and increments by minus a negative number, therefore increasing to infinity. What an idiot!
I tried ESC, but after 3 minutes, still no response. I hate hard rebooting it all the time. Should learn to be more careful at coding.
Mark
6 years 6 months ago #164191 by Mike_Eitel
Replied by Mike_Eitel on topic Retrofitting a 1986 Maho MH400E
Silly idea: what happens when you trigger a linit switsch
Moderators: piasdom
Time to create page: 0.343 seconds
