- Thank you received: 23
Retrofitting a 1986 Maho MH400E
- hanmon
6 years 5 months ago - 6 years 5 months ago #168965
by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Hi Mark,
no, it is all DIY with a Sumitomo Fine Cyclo Gear:
www.cncecke.de/forum/showthread.php?1026...chse-f%FCr-Maho-400E
I'm gonna use the 4 or 5-pin original connector of MAHO's fourth-axis feedback for my z-height setter or the 3D-Digitizer and the large multi-pin Harting connector for the axis.
The axis needs cables for servo, encoder and resolver.
The next pictures, maybe tomorrow, will show that
Last edit: 6 years 5 months ago by hanmon.
- RotarySMP
- Thank you received: 595
6 years 4 months ago - 6 years 4 months ago #170467
by RotarySMP
Cool, thisoldtony posted an update on his MAHO 400P project.
It really does show how much simpler machine tools have become since numeric control took over.
Last edit: 6 years 4 months ago by RotarySMP.
- Christophe C.
6 years 4 months ago #172153
by Christophe C.
Replied by Christophe C. on topic Retrofitting a 1986 Maho MH400E
Hello,
First, congrats for the hard work, that's a nice machine you have now. I've been myself restoring a MH800T for a Fablab here in France ( some pictures here ); it's a lot of work but these machines are worth it.
It's running on Heidenhain and it works great so no Linux CNC for now, but that's definitely something I'd like to do one day, to maybe add a 4th axis and that kind of stuff.
Anyway, loosing track here; I came to ask a question on your machine; I'm looking for an overarm support for horizontal milling for my machine, and I can't even find a picture of this support for 800 Maho - just a drawing on the user manual. I'm wondering if for some weird reason, the 400 and 800 may share the same support. The horizontal spindle has two bolt patterns; the largest one is used for the vertical milling head, and I have no clue what the smaller one is for, only thing I know is that it seems very similar to the bolt pattern on the 400 machine. I'm talking about these 4 threaded holes and two dowel pins :
Could you please measure the spacing of these threaded holes on your machine? Here are the measurements I have on the 800.
Thanks for you answer,
Christophe
Christophe
- RotarySMP
6 years 4 months ago - 6 years 4 months ago #172154
by RotarySMP
Hi Christophe,
The 800 is quite a beast! I looked at your thread. You have put a lot of work into that machine. Thanks for posting that link. It looks like you have a similar 18 speed gearbox as my little Maho, so if you do even need to retrofit it, you could use the gearbox comp for it.
When the shaping and horizontal support for a 400P came up for sale, I had the same question. I wrote to DMG and asked, and they responded by sending me this drawing from the shaping head mount. The hole pattern is 145mm wide, by 108mm high, I went in the basement and double checked that.
Either you need to improve your measuring accuracy considerably
, or the 800T needs bigger accessories. Sorry.
Mark
Mark
- Christophe C.
6 years 4 months ago #172155
by Christophe C.
I will sure come back to you if/when it goes Linux CNC. I'd better start working on that before the control die as having it running would make all the retro engineering much easier.
I've seen a video of your shaping head, it's a beauty. Not a word on these accessories in the user manual? Now I need one for the 800
Regarding my measurements, I made them on a blueprint with no scale so I may be off... but sure not by that much. I will double check next time I'll be near the machine - unfortunately it doesn't fit in my basement!
Thanks for taking the time to answer!
- chris mcm
6 years 2 months ago #178029
by chris mcm
Replied by chris mcm on topic Retrofitting a 1986 Maho MH400E
Hello All
You have not heard from me for a while. The capacitors were changed in the Indromat 3TRM 2. I used the machine today on a small project and all went well. I still have no DRO but that will happen shortly. We have bypassed the troublesome TNC . Impossible to do good work without the DRO as the only controls are at the consul so without reading numbers you can't see what you are doing on the work piece. I need to fit a foot switch for tool changing. Sorry about the delay. Some will think I have given up. Thanks to all who have supported me in the past. Cheers Chris .
Moderators: piasdom
Time to create page: 0.724 seconds
