Retrofitting a 1986 Maho MH400E
6 years 1 month ago - 6 years 1 month ago #183430 by RotarySMP
I guess if I have one mild criticism of open source culture, there is a bit of a tendency to keep throwing out the baby with the bath water and starting over from scratch especially with Gui. I never really understood what motivates people to start the ten thousand and first new GUI for linux. I realise you can just ignore them, but it gets confusing over time. Ubuntu was all the rage when I first tried LinuxCNC, a few years later, and it was Debian. Now Mint. Who cares about these things? They all do about the same thing, but none gets the sustained development to be awesome. I know as a non-programmer, I can't really add value to the conversation here though.
Norbert has done an amazing job of Gmoccapy, but like anything it would probably benefit from a wider circle of users and developers.
I guess that is a big thank you to the LinuxCNC core development group. You have sustained development long enough for this to be awesome.
Rod, thanks for your feedback on your Gmoccapy experience. It would have been easier to find a 16:9 monitor, but I avoided that because Gmoccapy is so well optimised for 4:3. When I see the supermarket staff use their touch screen monitors day in day out, they are obviously more robust and durable than we may give them credit for.
I guess you could add three buttons mapped to Jog/MDI/Run at the pendant. I am guess Norbert implemented the interface ignoring the pendant unless in the correct mode as s safety feature. I see that most industrial pendants have an additional interlock which you have to push to be able to operate them at all.
I am really tempted to start again on the pendant and do Peter (Talla83)'s one,
as that interfaces directly with the MESA hardware with just an ethernet cable. I have never soldered SMD boards before, but have a couple of his RS-422 Adapter to practice on.
Mark
Last edit: 6 years 1 month ago by RotarySMP.
6 years 1 month ago #183433 by rodw
Replied by rodw on topic Retrofitting a 1986 Maho MH400E
The move from Ubuntu to Debian was driven by open source licensing issues.
I think the move to mint was driven by a better user experience and the fact that pre-stretch preempt-rt if you had to compile the kernel to use a mesa card (like me), you might as well do it on Mint with better driver support and a nicer experience.
It would be nice if now the 2.8 release is over that the dev team could take Rob Murphy's work and release a Mint distro as they have given LCNC permission to do so.
BUt yes agree, its really an amazing project that has stood the test of time.
6 years 2 weeks ago - 6 years 2 weeks ago #185967 by chris mcm
Replied by chris mcm on topic Retrofitting a 1986 Maho MH400E
Further, thanks to this forum and especially Mark. The Maho 700c is now operational and I can use it. We have fitted an Easson DRO and managed to retain the Heidenhain X axis scale. It seems the Y and Z axis signal were not recognized by the Easson so we now have the standard Easson scales.
All the other features of the Maho work as before. The T.N.C has been isolated.
My Technician Brad has got to know the electrics of this Maho. At this point I am just happy to have the machine working as it is but it is likely we will carry on retrofit the same to Linux CNC.
I have another issue. The Horizontal spindle is leaking oil. I fear I have over filled it and flushed the grease out of the spindle. There is no sight glass or dip stick. Reading the manual I find only one reference. page 7.03-1 says after 2000 hours "Change the oil in the horizontal work spindle drive gear" 0.7 1. I presume this is .7 litres. I have not used the machine since over filling and tomorrow I will look at the daunting job of removing the spindle and repacking it with Kluber spindle grease. The recommended Kluber F 23 A. Is no longer available.
I am sure all this has been covered in the forum at some time. I have looked but the forum is huge!
Can I ask? Does the Kluber grease act as an oil seal in the spindle. The oil level must be very low to not flow through the bearings.
Any advise on lubrication or spindle removal would be helpful.
Thanks to every one who has helped me in the past, A great Forum!
Cheers Chris Auckland New Zealand
Last edit: 6 years 2 weeks ago by chris mcm. Reason: missed a word or three
6 years 2 weeks ago #186009 by ThisOldTony
Replied by ThisOldTony on topic Retrofitting a 1986 Maho MH400E
Re: leaking horizontal spindle. Did the same with an MH400. Turns out I did overfill it. (that, and it had a bit of a forward lean as it was half up on skates/shims). I didn't verify but am told the 400's use a labyrinth seal. Mine does have a sight glass, however.... and I overfilled it nonetheless. :)
Takes a while for oil to leak out w/o the spindle running. I let the excess drain into a catch pan. Took a couple of days, but fill level has stabilized (& I marked the sight glass).
Spindle runs fine, no leaks, consistent fill. I panicked for a while and even tore the motor off with the intention of rebuilding, but all is well.
Not sure what the 700 does, but food for thought.
Also, I didn't measure, but I'm sure it's more than 0.7L. At least on the 400, 0.7L probably wouldn't even wet the walls. If I were to guess, mine ended up with 3 maybe 4 liters? and the 700 is probably 1.75x bigger than the 400. :)
6 years 2 weeks ago #186033 by tommylight
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
@Tony,
Is your Maho finished with servos and everything?
Been busy so might have missed it.
6 years 2 weeks ago #186081 by chris mcm
Hello Tony
On the Maho C 700 there is the main transmission gear box and ahead of that a separate compartment ( oil bath) with two gear wheels that can slide on a spline to activate the horizontal spindle. The main transmission gearbox has a sight glass. The Technical Documentation indicates a volume of oil approx 1.2 litres.
The filler cap is just ahead of the electric motor. I have not found the drain plug for the main transmission.
The compartment with the drive gears has a similar filler cap. there is no sight glass or dip stick. And yes, I have found the drain plug.
A piece of wood doweling used as a dip stick showed the compartment dry. I wrongly added oil and the lower spindle leaked.
The Technical document says this compartment should have decimal point .7 litres of oil. The lower drive gear is close to the casting and turned by hand effectively picks up oil. So it appears that my over filling may be the problem.
I don't really want to mess with the spindles of this hardly ever used machine.
It is however over fifty years old and grease in the spindles must be way past their use by date.
Removal and greasing is covered in the technical documentation. Not clear is how the hydraulic tool change is released with the spindle. I believe the Hydraulic pipe draws out with the spindle. Can any one tell me whether the bearing can be greased without taking them out of the spindle.
Thanks for writing Tony. And yes, I have watched your inspirational videos.
Thanks for your effort and helping me via this Linuxcnc.org forum.
Chris McM Auckland New Zealand
Moderators: piasdom
Time to create page: 0.409 seconds
