Retrofitting a 1986 Maho MH400E
- chris mcm
1 year 7 months ago #325034
by chris mcm
Replied by chris mcm on topic Retrofitting a 1986 Maho MH400E
Hello David
No further in removing the springs on my Maho 700C
After getting no progress in getting the hydraulic tool changer working I hung the spindle from a crane and connected the hydraulic lines in reverse. Almost straight away I noticed a hydraulic leak. Not yet fixed but likely the cause of my problem
I would never have seen the leak when the spindle housing was in place in the machine. A new o ring is required
thanks for your help
Cheers Chris
Cheers Chris
- D Jensen
- Thank you received: 16
1 year 7 months ago - 1 year 7 months ago #325137
by D Jensen
Replied by D Jensen on topic Retrofitting a 1986 Maho MH400E
Hi Mark,I watched you re-grease the spindle on Youtube. I don't have much luck there as most of my post are removed in a few seconds. I haven't figured why.But I noticed your bespoke hand wheel. On mine it is held on with an off the shelf detent. Easy and neat.
David
David
Last edit: 1 year 7 months ago by D Jensen.
- D Jensen
1 year 7 months ago #325356
by D Jensen
I'm browsing through your build of the lathe and I think somewhere there you got into a discussion of ChatGPT.
I've been feeding AI's G code for a while now to see how it goes. It's still hopeless. And I noted you mention it didn't understand subprograms. That also applies to program flow in general.
It occurred to me that in most cases where it's scraping the entire knowledge on the planet, it usually gets to see a coding problem and attached it sees a printout of the answer.
In our case the "printout" is actually the movements of the machine itself. So I suspect what it needs to train on is a video of the machine movements with a picture in picture of a block of execution concurrent with what that block does on the machines move.
Not likely to scrape that currently off the internet I suspect.
But there are AI programs that now do very realistic art, movies and presentations of people who are dead saying modern speeches etc.
So it should be possible to combine both types of AI to make really fantastic CNC programs?.
You've seen how I usually put a lot of comments that explain every line of my G code I think?
If I remove the comments the AI is hopeless. It will give a vaguely generic statement of what some of the lines mean. If I leave the comments in it does better, but if you look you see that has just cleverly reworded the comments. It does no better with the code at all.
Maybe someone in the LinuxCNC community knows someone in the AI community who could run with the concurrent video/ block by block idea. Nearly every CNC machine on earth uses G code and it would be great if we could just get an AI to program them all.
Cheers.
David
Cheers.
David
- D Jensen
1 year 7 months ago #325360
by D Jensen
Hi Mark,
I watched one of your Youtube videos again on the wonderful tool made for you by the guy in Malta. Nice to have friends like that.
A lot of good comments there. But I don't think you can add photos to the comments. So I'll stick my nose in here instead.
It's and area that makes my head swim. But it seems to me that the method is really just about making the quill square to the table. The vertical head on our machines only rotates around the Y axis, but on many Bridgeports it can also rotate around the X axis. In that case you could use the device to make the quill perfectly square to the table. But you could also tilt their table to any angle (some can do that) and tilt the head to be perfectly square to that using your device. Then you could use the quill to drill nice holes. You might do that to fit an oversized object perhaps? But it would do nasty things to the drill if you moved the knee while drilling. An extreme case example. Feel free to call me and idiot if I'm seeing it wrong.
My machine has that nice taper roller grinder style quill, which has a slight preload. So no looseness, but it will still have non repetitive run-out errors due to the various manufacturing errors in rollers etc.
On my machine you can see there is a detent knob on the head tilting. It clicks home at zero degrees on the tilt dial. When I put my dial clock on it then and swing it I get almost perfect alignment in the X direction. Big surprise! The head rotation clamps just like yours but with 4 bolts. You can see they scribed the zero mark on the head after they did the alignment by the missing paint.
I've added a photo of when my rotary table is removed. You can see the 8 bolts that clamp it on (so I don't misplace them). There are keys on the rotary table that fix the tilt when it's assembled. You can see it's not a dovetail system. I suspect I could align the table sag by removing that array of bolts along the bottom and putting shims between that X slide and the bearing rails.
Cheers,
David
Cheers,
David
The following user(s) said Thank You: chris mcm
- chris mcm
1 year 7 months ago #325373
by chris mcm
Hello David
t seems we have been writing under Linux CNC forum and possibly a bit off topic.
If you are happy to continue our conversation please advise me on how best to contact you.
Thank you Cheers Chris McMullen
- D Jensen
1 year 7 months ago #325375
by D Jensen
I agree. At the rate I'm going I'm liable to get kicked off!
You can contact me at:
david.jensen1@optusnet.com.au
Or better on Skype at:
david.jensen11 although that is going off air next month and I will be migrated to Teams personal or Teams free it seems.
Skype is better for me as I'm slow and hopeless at typing. You might need to refine the Skype address to Sydney.
Cheers,
David
Cheers,
David
Moderators: piasdom
Time to create page: 0.193 seconds
