Retrofitting a 1986 Maho MH400E
6 months 3 weeks ago #345252 by Tserakhau
Replied by Tserakhau on topic Retrofitting a 1986 Maho MH400E
  Good afternoon.My name is Victor, and I'm restoring a MAHO 600E milling machine and converting it to Linux (the original Philips operating system).Thank you so much for this thread; many questions were resolved using the forum.I received the machine without a spindle motor, coolant system, and most relays.I've already done almost everything; the machine moves and finds its home position.I installed and tested the speed control box; all speeds shift perfectly! (The box is completely identical to yours, although the motors are installed slightly differently.)I've also already configured the lubrication system, hydraulic clamp, and MPG control panel.My question is: what needs to be done next after setting up the simulator? How do I implement this into the .ini or .hal files?I apologize for any inaccuracies in the text of this message; I'm using Google Translate because my English is poor.
6 months 3 weeks ago #345268 by RotarySMP
Have you already compiled the gearbox comp? I have attached my HAL and Ini files, so you can see the pins you need to connect.
Cheers;
Mark
6 months 3 weeks ago #345309 by Tserakhau
Thank you so much! I'm looking through your files. I'll definitely let you know the results!
6 months 2 weeks ago #345631 by Tserakhau
net sig_reducer_left_center  mh400e-gearbox.reducer-left-center <= hm2_5i25.0.7i84.0.2.input-03
net sig_middle_left_center   mh400e-gearbox.middle-left-center  <= hm2_5i25.0.7i84.0.2.input-07
net sig_input_left_center    mh400e-gearbox.input-left-center   <= hm2_5i25.0.7i84.0.2.input-11
I don't have such inputs on my machine. They are on the 28A1, but they are not in the loops. They immediately increase the resistance when triggered, but do not go to the controller. Can I configure the switching without connecting these signals?
6 months 2 weeks ago #345646 by RotarySMP
You will need to modify the gearbox comp and recompile it. I didn't write it myself, it was written for me by a friend, so you might need to find someone to do the code changes.
6 months 1 week ago #345736 by Tserakhau
Hello
I figured out the center positions (muted them in the HAL, combining them with the middle position).
All gears shift perfectly!!!
The only thing I can't figure out is why F9 always engages first gear
and after the spindle stops (with any stop command), the transmission shifts to neutral. Is this how it should be, or have I messed up something in the HAL?
Moderators: piasdom
Time to create page: 0.504 seconds
