- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
8 years 1 month ago #117017
by RotarySMP
Thanks John,
Is this logic correct then...
If the gearbox is not in mesh, and no switch is closed then current position between LH and MID, -->turn CCW to the LH and CW to mid position.
else if
gearbox not in mesh, and LEFT_CENTER switch closed, then current position between MID and RH and RH, --> turn CCW to mid and CW to RH
Mark
else if
Mark
- drimaropoylos
- Thank you received: 40
8 years 1 month ago #117021
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
- drimaropoylos
8 years 1 month ago #117023
by drimaropoylos
www.flickr.com/photos/mahomh600p/
www.flickr.com/photos/mahomh600p/8293681086
Even if the motors overshoot just a little the gearbox has some ball locking mechanism.
- RotarySMP
8 years 1 month ago #117025
by RotarySMP
Thanks again John, that is much clearer now.
I just took a look through those photos. What a great reference.
Mark
Mark
- RotarySMP
8 years 1 month ago - 8 years 1 month ago #117249
by RotarySMP
My friend has made great progress on the gearbox.comp and a gearbox simulator to test it...
Github Wiki
It is looking really good.
I have a question about the mechanical's of the gear change motors.
They are rated:
U=24v
I=0.8A
n=28 rpm
P2=6W.
I am "Assuming" that these motors are so wimpy that if I run them into a hard stop due to the having a direction sense reversed in the software, they should stall without an tooth decay on the plastic gears. Am I being unrealistically optimistic here?
I also have a question with regards to the matrix-KB pin:
matrix_kb.MAHO_Panel.col-1-in
does the column and row numbering start at 0 or 1?
Mark
Github Wiki
They are rated:
U=24v
I=0.8A
n=28 rpm
P2=6W.
Mark
Last edit: 8 years 1 month ago by RotarySMP.
- Thank you received: 7491
8 years 1 month ago #117262
I own a gear motor that is rated a bit higher at 24V/2A that would beg to differ, the very first time it hit a hard stop it chewed the plastic gears, and it was powered by a cordless drill battery at 14.4V, but it had enough current to render it unusable. If they are driven by relays, i would not risk it. Using current limiters is advisable, or a power supply with 1A max with automatic current limiting. Laptop adapters are very nice for such things but they tend to be in the 3.62A or 4.5A or 6.7A variety, so to much for your needs.
Or get some buck voltage regulars with current limiting for 1 to 3$ a piece on fleebay and set the voltage to 20V on their outputs a limit current to 1A. Used plenty of those to limit the current to motor drives that had no current limiting.
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
Moderators: piasdom
Time to create page: 1.025 seconds
