Retrofitting a 1986 Maho MH400E
8 years 1 month ago #117703
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
You probably need "addf mh400e-gearbox servo-thread (ie, a hyphen not an underscore in the function name)
In theory HAL only uses hyphens, but file-names can not contain hyphens, so the loadrt is underscores)
- RotarySMP
- Thank you received: 595
8 years 1 month ago - 8 years 1 month ago #117716
by RotarySMP
Thanks Andy, Sergey had pointed out that the HALcompiler changes underscores to dashs, and I tried both, but I didn't try the combination of underscore in the name and dash in the addf. I'll try that out tonight.
Mark
loadrt mh400e_gearbox
Mark
Last edit: 8 years 1 month ago by RotarySMP.
- RotarySMP
8 years 1 month ago - 8 years 1 month ago #117738
by RotarySMP
That worked. I then went on to correct at least 45 other typo bugs in my ~45 lines added to the HAL to interface with the gearbox. You guys might have noticed that my typing is pretty rough
I wanted to test only the gearbox, and since the glass scale encoder on both Y and Z axis are currently U/S, can't home the machine.
In the ini, I edited the current homing lines to immediate homing :
Are those "o" or zero's? I used zero's, but I see today that they look like "o"'s.
First I just commented out the existing settings like this...
LinuxCNC can't deal with comments in this line of the ini. I freezes during the GUI load and has to be manually killed. Moving the comment to the line before corrected that. I see that this behaviour is already described in the INI knowledge file .
When I tested it, the X axis raced off till it hit the hard wired end stop and E-Stopped. Does this immediate homing not work on a closed loop servo axis?
Mark
HOME_USE_INDEX = NO # reset to yes.
Mark
8 years 1 month ago #117739
It should work. But the servo loop won't work without the position feedback, and you already said that was broken. (though the system still should have f-errored).
Maybe don't enable the servos yet?
Defintely zeros.RotarySMP wrote: Are those "o" or zero's? I used zero's, but I see today that they look like "o"'s.
- RotarySMP
8 years 1 month ago #117742
by RotarySMP
I understand the Z and Y axis being unpredictable without their encoder feedback, but the X axis has a working encoder, and yet it ran away. My understand of that it should have just homed were it was sitting.
Since I did a LiveCD install, the Gmoccapy Simulator is an easy install. I think I'll install that, and only cut paste the HAL lines necessary to continue testing the gearbox.comp interface, rather working with my machine.hal.
Mark
Mark
- drimaropoylos
- Thank you received: 40
8 years 1 month ago #117778
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Hello, congratulations on the progress of the gearbox control. The twitching of the motor (800 ms right, 200 ms off, 800ms left, 200 ms off ) is constant during the hole gear change and indepentand from the cams position, or ther is some relation?
Moderators: piasdom
Time to create page: 0.345 seconds
