Retrofitting a 1986 Maho MH400E
- RotarySMP
- Thank you received: 595
I connected the 602/1-F EXE and sent it to home. Opened a HALScope, and looked at the signal while manually turning Y, and could see that the signal looked good by with much lower resolution. Change the scale in the INI from -1000 to -200 and it has worked. I do notice that there is still a rythmic oscillation in Y between adjacent 0.005mm positions when stationary. I was never that happy with the tuning of Y ( in hindsight that was probably tied up with the drift). I'll retune that axis no it is stable and report back.
Next steps:
- I still have to get my panel encoders working. They are wired, and the buttons work, but the encoder signals aren't.
- Sergey is working on a revision to the gearbox comp to give the comp full control of the spindle and address that isue of going to neutral each stop, and thus not completing gear changes from a running spindle.
- I need to make the pendant. Touching off with the touch screen is a PITA.
- The dolley design needs completing and it manufactured, so I can finally try and fit this through the skinny door into the machine shop.
- I picked up a mist coolant system at some point, and would like to integrate that next time the covers come off.
- When fitting the new bellows I notice one oil line had been crushed on a previous cover installation, so it need replacing.
Since I practice analysis paralysis, I challenged myself to whip up a knife sharpening jig out of junk that was laying around, in one quick session without stopping. Made this in about 15 minutes.
Considering the tie wraps and double sided tape holding it together it works pretty well. Now it gets improved. I have already made stone holder with four grits of stone. Next I want to design and mill a decent knife holder.
Mark
- hanmon
- Thank you received: 23
my Maho works. The pendant is still missing but it does not have a high priority. I'm going to start building a fourth axis in 1-2 weeks and, of course, will post some pictures then.
- RotarySMP
MArk
- R2AIV
- R2AIV
If you have any recommendations with respect to the gearbox.comp, please post them here, and I can discuss them with Sergey.
MArk
Hi, Mark! What reasons to rewrite gerbox component? It have troubles or bugs?
- RotarySMP
When you command M5 spindle stop, in addition to the spindle motor being stopped, linuxCNC commands spindle speed 0. When the stop command is passed to the MAHO relays, it sets the 5 sec timer relay, which then returns "Spindle is stopped".
The gearbox comp receives that signal, which releases it's inhibit from changing gear with a moving spindle.
Gearbox.comp now reacts to its new commanded speed being S0 by setting neutral.
Currently, the gearbox.comp can not complete a gearchange started from a running spindle (like if you command a different S speed in the middle of a program) due to this.
What happens: Spindle running at 600 rpm, receives an S1000 command. Since the spindle is running, it is inhibited from changing gear, so it commands LinuxCNC to stop the spindle. The action above happens. SInce LinuCNC has overwritten the S1000 command with S0, the spindle never restarts, but rather goes into neutral.
You can work around that with the current comp by using this as speed change code:
M5
G4 P6 ; wait for spindle to have stopped
S1000 M3; Command new speed from a stopped spindle.Sergey is revising the comp to give it control of the spindle relays. If LinuxCNC wants the spindle stopped, it will ask the comp, rather than the other way around. Ten when the comp is just changing speed, we wont tell LinuxCNC that the spindle is stopped, so it wont command S0.
He will also add an input pin to the comp, so if you want the gearbox put into neutral for safety (using a touch probe), you can do that with a hardware or software button.
Mark
- RotarySMP
In Hanmon's HAL only gearbox and "spindle stopped" signals is routed, but MAHO have few another signal like lube, tool fixation, some spindle signals. What i must to with these signals?
What model do you have?
On my 400E, the oiling system logic is hard coded into the lube unit with a timer relay. Look back a few pages, as Hanno posted a detailed post about how he set up his oiling logic.
I have my Tool release netted to a hard button on the control panel, through a 7i77 pin, so I push and hold the button to drop or load a tool.
The gearbox comp needs:
# --- GEARBOX CONTROL ---
net sig_return_actual_speed mh400e-gearbox.spindle-speed-out => motion.spindle-speed-in
net sig_return_spindle-at-speed mh400e-gearbox.spindle-at-speed => motion.spindle-at-speed
net sig_stop_spindle mh400e-gearbox.stop-spindle => halui.spindle.stop
net set-gear-shift-start mh400e-gearbox.start-gear-shift => hm2_5i25.0.7i84.0.2.output-05
net set-reverse-shaft-motor mh400e-gearbox.reverse-direction => hm2_5i25.0.7i84.0.2.output-04
net activate-reducer-motor mh400e-gearbox.reducer-motor => hm2_5i25.0.7i84.0.2.output-01
net activate-midrange-motor mh400e-gearbox.midrange-motor => hm2_5i25.0.7i84.0.2.output-02
net set-shaft-motor-lowspeed mh400e-gearbox.motor-lowspeed => hm2_5i25.0.7i84.0.2.output-00 # MAHO calls this Anwahl Mittelstellung
net activate-input-stage-motor mh400e-gearbox.input-stage-motor => hm2_5i25.0.7i84.0.2.output-03
net activate-spindle-twitch-cw mh400e-gearbox.twitch-cw => hm2_5i25.0.7i84.0.2.output-06
net activate-spindle-twitch-ccw mh400e-gearbox.twitch-ccw => hm2_5i25.0.7i84.0.2.output-07
net sig_get_commanded_speed mh400e-gearbox.spindle-speed-in-abs <= motion.spindle-speed-out-abs
net sig_spindle_status mh400e-gearbox.spindle-stopped <= hm2_5i25.0.7i84.0.2.input-19
net sig_reducer_left mh400e-gearbox.reducer-left <= hm2_5i25.0.7i84.0.2.input-00
net sig_reducer_right mh400e-gearbox.reducer-right <= hm2_5i25.0.7i84.0.2.input-01
net sig_reducer_center mh400e-gearbox.reducer-center <= hm2_5i25.0.7i84.0.2.input-02
net sig_reducer_left_center mh400e-gearbox.reducer-left-center <= hm2_5i25.0.7i84.0.2.input-03
net sig_middle_left mh400e-gearbox.middle-left <= hm2_5i25.0.7i84.0.2.input-04
net sig_middle_right mh400e-gearbox.middle-right <= hm2_5i25.0.7i84.0.2.input-05
net sig_middle_center mh400e-gearbox.middle-center <= hm2_5i25.0.7i84.0.2.input-06
net sig_middle_left_center mh400e-gearbox.middle-left-center <= hm2_5i25.0.7i84.0.2.input-07
net sig_input_left mh400e-gearbox.input-left <= hm2_5i25.0.7i84.0.2.input-08
net sig_input_right mh400e-gearbox.input-right <= hm2_5i25.0.7i84.0.2.input-09
net sig_input_center mh400e-gearbox.input-center <= hm2_5i25.0.7i84.0.2.input-10
net sig_input_left_center mh400e-gearbox.input-left-center <= hm2_5i25.0.7i84.0.2.input-11Note, misusing halui.spindle.stop for the gearbox.comp is one of the things the revision will correct.
Mark
I _think_ that M5 still gives S0, though I can see arguments that it shouldn't.
- RotarySMP
Mark
linuxcnc.org/docs/devel/html/man/man9/motion.9.htmlThanks for that Andy. Where do we find those new pin names?
No idea. I was hoping that it would be around last new-year.Any Idea when 2.8 will be released?
The release manager has gone rather quiet....
