converting a tos/intos fngj 40
23 Nov 2024 15:56 #315114 by PCW
Replied by PCW on topic converting a tos/intos fngj 40
Unfortunately, pin 8 is a disable input rather than an enable input so the
polarity of the 7I77 enable outputs are wrong (off until enabled). It may require
a relay with a NC contact driven by say a 7I77 digital output as drive enable.
(I think one relay will work for all axis by connecting all pin 8's together)
The following user(s) said Thank You: FPM
22 Mar 2025 16:59 #324567 by FPM
Replied by FPM on topic converting a tos/intos fngj 40
Does anyone use jmc integrated servos with a 7i77?
I know they work with pulse/dir but in the manual they mention some kind of external analog instruction, but nothing about +/-10v.
Or is there any other other possibility to drive them with a 7i77?
Manual:
www.rocketronics.de/download/datasheet/i...v_v6_2020_manual.pdf
22 Mar 2025 22:23 #324591 by ihavenofish
Replied by ihavenofish on topic converting a tos/intos fngj 40
they are not analogue. they are step and direction or ethercat only.
02 Apr 2025 17:42 #325533 by FPM
Thanks for the info!
I've ordered a 7i78 now.
Is there anywhere a bitfile for the 7c81 with 7i77+7i78 available?
02 Apr 2025 18:26 #325534 by PCW
File Name: 7c81_7i77x...8x1d.zip
File Size:110 KB
The following user(s) said Thank You: andypugh, FPM
18 Apr 2025 12:01 - 18 Apr 2025 12:03 #326594 by FPM
I connected the 7i77 to p1 and the 7i78 to p2, i assume this is the correct order.
I've tried to modify the hal so that the z-Axis is the stepper connected to the first interface of the 7i78. The encoder for the z-axis is connected to the 7i77. Is this more or less done correctly? (hal is attached).
Since the 7i78 has no enable signals for the steppers, is it possible to use the enable pin from the spindle, since i am not using this? and how do i need to mod the hal?
Thanks!
File Name: intos.hal
File Size:10 KB
Last edit: 18 Apr 2025 12:03 by FPM.
18 Apr 2025 14:15 #326604 by PCW
What are the specifications of the enable input?
You may be able to use a 7I77 field output if it will take say a +24V signal
18 Apr 2025 16:13 #326607 by FPM
The enable is a 5v differential input.
The Manual says:
"Enabling signal: This input signal is used to enable or
prohibit; In addition, it can be used to clear the drive alarm.
When ENA + is connected to +5 V, ENA-is connected to
low power, the drive will cut off the current of each phase
of the motor so that the motor is in a free state, where the
pulse is not responded and the alarm can be cleared; When
this function is not required, the energy signal end is
suspended."
  • Moderator
  • Moderator
18 Apr 2025 16:16 #326608 by tommylight
Replied by tommylight on topic converting a tos/intos fngj 40
Seems like "disable" signal, not enable, as with most cheap drives lately.
18 Apr 2025 17:25 #326615 by PCW
Yes, in this case, I would probably just leave it disconnected.
(unless you need to disable the drives so that the shafts are freewheeling)
If you have a free step/dir output on the 7I78 that can be used as a 5V
enable output
Moderators: piasdom
Time to create page: 0.218 seconds
