converting a tos/intos fngj 40
- FPM
27 Apr 2025 13:00 - 27 Apr 2025 13:01 #327144
by FPM
Replied by FPM on topic converting a tos/intos fngj 40
I have connected everything and flashed the bitfile from PCW. But it looks i have not configured the second card in the hal properly.
Attached the output of mesaflash readhmi, the hal and the crash report from lcnc
any ideas?
thanks in advance.
any ideas?
thanks in advance.
Last edit: 27 Apr 2025 13:01 by FPM.
- Thank you received: 7496
27 Apr 2025 13:20 #327150
Replied by tommylight on topic converting a tos/intos fngj 40
HAL: ERROR: function 'hm2_7c81.1.read' not found
./intos.hal:16: addf failed
should be
hm2_7c81.0.read
should be
hm2_7c81.0.read
- FPM
27 Apr 2025 13:50 #327155
by FPM
thanks for your fast reply.
if you read in the hal, there is written :
addf hm2_7c81.0.read
addf hm2_7c81.1.read
for both cards
.0 is the 7i77 and .1 is the 7i78
I interpreted the documentation that it should be done like this.
Any advice how it is configured correctly?
for both cards
27 Apr 2025 13:59 #327157
How many 7c81 are in use?
for one only, delete the line containing 1
Pretty sure this should only be used if you have 2 of 7c81, 0 and 1 there are enumeration for 2 of 7c81 not the add on cards, they do have their own enumeration after the model number, example:
hm2_7c81.0.7i77.0.0.input-07
First 7c81 that has the first 7i77 attached, first is always 0 with Mesa and LinuxCNC enumeration.
Had a look at your hal, there is more editing required, so it might be easier to make a new config with a single 7c81.
- FPM
27 Apr 2025 14:28 - 27 Apr 2025 14:58 #327164
by FPM
only one 7c81, you tip has done the trick. Thank you!
but the next problem occured
The error changed to:
/intos.hal:88: parameter or pin 'hm2_7c81.0.7i77.0.1.analogout0-scalemax' not found
so checked this line in the old, working hal, without the 7i78, and its exactly the same. What does change here when i use 2 daughterboards?
Any Ideas?
EDIT:
i have also tried to change the channel number to 0:
hm2_7c81.0.7i77.0.0.analogout0-scalemax'
and 2 and 3
Any Ideas?
EDIT:
and 2 and 3
Last edit: 27 Apr 2025 14:58 by FPM.
27 Apr 2025 15:05 #327167
Try omitting that line with scalemax, right now i can not recall i ever used it.
Just add # in front of the line, save, test.
- FPM
16 Jul 2025 13:15 #331898
by FPM
Unfortunately my pi4 in the machine died. The 7c81 seems fine, i even reflashed the 7c81 with the right bitfile, just to be sure, no errors. So i switched to a pi5, but the previously working config gives me an error.
spi in the kernel config is activated.
Any ideas?
Any ideas?
- Thank you received: 5335
16 Jul 2025 14:27 #331903
Replied by PCW on topic converting a tos/intos fngj 40
The RPI5 needs the newer ( hm2_spix ) driver.
- FPM
02 Oct 2025 12:49 - 02 Oct 2025 16:15 #335715
by FPM
Hello,
unfortunately I ran into the next problem
I was tuning my servos, in the calibration tab and saved the settings. The Machine behaved as expected. when i restartet LCNC the movements of the machine were jerky and ended up in positioning errors. So I set the the values back to something that just moves and repeated the process. Saved the settings and even checked the .ini if the values have been stored correctly. no problem. But as soon as i restart LCNC same problem. The values of the second tuning process ended up being more or less the same as the first time.
Am I missing something here?
EDIT:
The problem was me... i messed up something in the ini Seems to work now.
EDIT:
Last edit: 02 Oct 2025 16:15 by FPM.
Moderators: piasdom
Time to create page: 2.026 seconds
