Retrofitting Deckel FP4ATC
9 months 3 weeks ago #341015 by Hartwig
Replied by Hartwig on topic Retrofitting Deckel FP4ATC
Hi Mbrandt,
I am using the Mesa 7i97T for 4 seperate axes with Heidenhain encoders and Tacho DC servo motors on my milling machine.
My servo amplifiers get the setpoint +- 10V and the Enable signal from the Mesa card. Very simple and straightforward. The inputs from the Heidenhain EXE ( I would assume, that your machine has the Heidenhain EXE card/units on board) are also easy to connect. The read-out of the positions worked immediately.
I bought the MESA card from EUSurplus in Portugal - the only source, where it was available in Europe, Highly recommended dealer.
Best regards
Hartwig
9 months 3 weeks ago #341046 by Mbrand1901
Hello Hartwig,
Thank you for your reply. I think my machine has some sort of EXE, its a board and the name is NCP59. But i dont know where to intercept the TTL signal from it. There is a version of this board with an extra digital output, but i dont have it on my machine. And buying 3 Heidenhein EXE is a step back. I would like to use a modern version of that.  Maybe a 7i85S or someting like that?
And the Suplier you sent seams good and I will buy der 7i97T from him.
Here is a picture of the NCP 59:
(1, 2, 3 are X, Y, Z)
9 months 3 weeks ago - 5 months 3 days ago #341050 by Hartwig
No eBay APP ID and/or Cert ID defined in Kunena configurationHello Mbrandt.
I have used the following type of "HDH Exe Platine" with 3 channels.
Very simple and very small. It fits between the glas scales and to the MESA directly. For mine I have paid less than 200 Euro.
Last edit: 5 months 3 days ago by Aciera. Reason: Remove failed upload, see image in the post below
9 months 3 weeks ago #341051 by Hartwig
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Sorry for the previous message. I hope, this works.
Best regards
Hartwig
9 months 3 weeks ago - 9 months 3 weeks ago #341081 by reboots
Replied by reboots on topic Retrofitting Deckel FP4ATC
I can't advise on whether there are Mesa cards which can work directly with the Heidenhain scales. EXE610C units are cheap on eBay here, so I purchased 3 for my FP2NC conversion. Meridian Measurement Systems has a newer converter product, which I suspect is based on the iC-Haus iC-NV chip:
meridianmeasurement.com/sa/
www.ichaus.de/product/iC-NV/
I plan to use a 6i25 and 7i77 Mesa Plug-N-Go kit, which I already had on hand. The conversion isn't finished yet.
Last edit: 9 months 3 weeks ago by reboots.
9 months 3 weeks ago - 9 months 3 weeks ago #341110 by Mbrand1901
Hello!
The idea with the Heidenhein board isn't bad. It's definitely a very solid solution.
I have already asked another company about these small converters. If they are suitable I would like to use them because they are small.
www.hs-imagingsolutions.com/hardware/signalkonverter
@hartwig, you can edit your comment to delete the long link
Last edit: 9 months 3 weeks ago by Mbrand1901.
Time to create page: 0.082 seconds
