Forum Header
Help please !!! Servo configuration with stepconf.
14 years 5 months ago #19766
Replied by andypugh on topic Re:Help please !!! Servo configuration with stepconf.
ishman wrote:
I think that turning it on is the only practical way to get more speed.
Work out what physical distance one encoder count is, and compare that to your desired machine accuracy, and adjust the electronic gearing to suit.
On a very simple level, your 2500PPR encoder servo is acting like a 2500 step/rev stepper motor, and 200 steps/rev is usual. 4:1 electronic gearing would give you a lot more speed and probably still adequate resolution.
I am running it with electronic gearing disabled.
- ishman
14 years 5 months ago #19769
by ishman
Replied by ishman on topic Re:Help please !!! Servo configuration with stepconf.
Thanks ! it's basic and useful knowledge.
So then I should put 10000 in motor step per revolution at axis configuration window.
But should I put the driver micro-stepping ratio in wizard when I use drives electronic gear ?
Most annoying queries for me is at "Basic Machine Configuration" page where it's asking "step time" , " step space" , "direction hold" and " direction setup". I don't know how to calculate these numbers.
- BigJohnT
- Thank you received: 994
14 years 5 months ago #19770
by BigJohnT
Replied by BigJohnT on topic Re:Help please !!! Servo configuration with stepconf.
According to your manual the Maximum Input Pulse Frequency is 500KHz. I'm not good with KHz and I assume that is minimum of both the on and off time of a step.
- ishman
14 years 5 months ago #19779
by ishman
BigJohnT wrote:
It means a billion divide by 500k = 2000 is it a correct number for step time ? I hope so.
- ishman
14 years 5 months ago #19780
by ishman
Yes ! I have confirmed. It's total 2 microseconds (2000ns) for an entire pulse frequency. We just have to divide in two for step time and step space. It means 1000 for "step time" and 1000 for "step space" THANKS JOHN !
Can anyone explain about what is actually "Direction Hold" and "Direction Setup" ?
14 years 5 months ago #19781
ishman wrote:
Probably not all that relevant with that drive. But a you always stop before changing direction, it doesn't matter too much. 20,000 ought to be safe.Can anyone explain about what is actually "Direction Hold" and "Direction Setup" ?
Time to create page: 0.144 seconds
