Forum Header
Mach 3 conversion to Stepconf Wizard
11 years 5 months ago #59031 by Serpentus
Hi BigJohnT, Could you please convert my file also? (Maybe you forgot to do it before xD). If you can't, then thanks anyways, but please tell me to format that partition and use it for something else..
It's a Syil x7 plus from the year 2014 with 4 axis, XYZA. (Just adding the model and year just in case someone has the same machine and also wants the file).
The Mach3 configuration is in metric by the way.
Thanks a lot! :)
The topic has been locked.
11 years 5 months ago #59290 by palmfans
Hi John, could you help convering the MX4660 Mach 3 file for me.
Thanks a lot.
palmfans
File Name: xmlfileoft....xml.zip
File Size:17.33 KB
11 years 4 months ago #59623 by racedirector
Hi there BigJohnT
Would appreciate the conversion of my Mach3 settings, I have included the 2 I use in the zip, the main and mostly used one is the metric one (Mach3 doesn't play nicely just using G20/G21)
Cheers
Bruce
File Name: Mach3Setti...mbat.zip
File Size:54.74 KB
11 years 4 months ago #59739 by Marfil
Hi. Cuold I send you my xml file? Thanks a lot.
File Name: Marfil.zip
File Size:9.56 KB
11 years 3 months ago #60587 by escott
Hello John,
Please could you convert a Mach 3 Denford Easiturn config for me.
Thanks,
Edward
11 years 3 months ago #61008 by golem
Hi!
Would you like to make conversion for me?
hank you,
Daniel
Time to create page: 0.375 seconds
