golem wrote: Thank you for answer, I have installed 2.7.9 pre6 and there is not option.
File you added in attachement is btw the same file I was posting.
Would you like to add converted file?
Thank you.
I just checked and I have LINUXCNC - 2.7.0~pre6 and the import option is there. There is no 2.7.9 so I assume that is a typo.
Yes, it was type mistake.
Right version is 2.7.0 pre6 (linuxcnc info show me this number).
I made fresh install of Ubuntu 12.04 and then I installed linuxcnc from repo.
(according to point 3.7.2 from page:
linuxcnc.org/docs/2.7/html/getting-started/
I didn't use disk image, maybe it is reason not to show this option?
No, I'm running a Run In Place (RIP) so I have the latest code. Until the code that was added after pre6 was released you won't see it the way you installed. I think they are jumping up and down to release 2.7.0 (no pre) and it will be there.
Hi JT,
could you convert my 2 axis lathe xml file please?
I upgraded from 2.6 to 2.7 pre6 hoping to get the stepconfig wizard with the Mach 3 import option but it does not show it
Thank you
Gerry
I used the new Stepconf Wizard to create your configuration then zipped up the configuration directory. Put the 2AxisLathe directory with the files in the /linuxcnc/configs directory. The .stepconf file goes in the configs directory.
