Forum Header
Linuxcnc - plasma router - joint 2 flolowing error
5 years 8 months ago #197642 by kofaki
i don't know,,,,but i try it :) ......thank you Rodw :)
5 years 8 months ago - 5 years 8 months ago #197676 by kofaki
Ok, sheetcam is fine, now i have still problem with torch height.
If i cut some small holes, then i have the error " Valid Arc Lost" or "Float Switch Activated Program Paused"
I think, that if i try cutting through small steel plate (thick 2mm), then the problem is more frequent, because the steel still bended.
Maybe some bad settings .....i tried change the 'cut height' from 2 - 4 mm and 'feed rate' from 200 - 2000 mm/min.
If i tried cut for example "STAR" into big steel plate (thick 3 mm), then all is OK.
My last question is : the PROMA THC is set now for 162V. This voltage must be changed for different thick of steel plate or is the stable one value ?
Many thanks,
Last edit: 5 years 8 months ago by kofaki.
5 years 8 months ago #197678 by kofaki
Additional information: I do not have a water bath yet ...
5 years 8 months ago - 5 years 8 months ago #198006 by razplaz
"My last question is : the PROMA THC is set now for 162V. This voltage must be changed for different thick of steel plate or is the stable one value ?"
Hi, on my Proma SD I change the voltage settings for different thicknesses of steel. For mine with Hypertherm Powermax 45XP using 50:1 voltage divider; 99v for 11 ga, 103v for 7 ga, 105v for 1/4", 110v for 1/2".
Last edit: 5 years 8 months ago by razplaz. Reason: add detail
Time to create page: 0.264 seconds
