Forum Header
Linuxcnc - plasma router - joint 2 flolowing error
7 years 3 months ago #141016 by kofaki
Hello Tomy,
i changed the config from Grotius (i found it in post forum.linuxcnc.org/plasma-laser/34978-th...-with-how-to?start=0) and this is the error :
Debug file information: . ./stepper.hal:45: Pin 'joint.0.motor-pos-cmd' does not exist 5793 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components
What is please wrong ?
7 years 3 months ago #141026 by tommylight
What version of Linuxcnc are you using ?
That config is for 2.8 or 2.9, it will not work with 2.7 as it has joint/axis info in it.
7 years 3 months ago #141038 by kofaki
aahhh, thank you, yeah, i use now 2.7. I upgrade it to 2.8
7 years 2 weeks ago - 7 years 2 weeks ago #148009 by kofaki
]Hello Tommy,
I didn't have time previously to continue building the plasma.
...Today I had a free day, i created a video with the error "joint 2 on limit switch error" . This error is loaded if drive axis Y.
Do you have any ideas, what is the fails ?
Many thanks,
Last edit: 7 years 2 weeks ago by kofaki.
7 years 2 weeks ago - 7 years 2 weeks ago #148010 by PCW
Possible reasons:
Limit switch broken
Limit switch polarity wrong
Limit switch wiring wrong
Noise on limit switch input
Wrong HOME_OFFSET or other homing settings in your .ini file
I would check the first three by monitoring the limit switch pin when doing a manual limit switch actuation
A noise problem will typically show up randomly (random places) or when some noisy device is activated
Posting your ini and hal files would allow forum members to see if your homing setup is correct
Last edit: 7 years 2 weeks ago by PCW.
Time to create page: 0.310 seconds
