- Thank you received: 7491
To be able to do that for any of the huge variety of machines that LinuxCNC can control, it would require the software to be SENTIENT!!!LinuxCNC should have some auto config option where you just let it run and it figures out where the home switchs are and everything.
Yes it is, granted you set the soft limits correctly in the wizard or in the ini file.Is it okay to set it as just "Home X"?
for I = 1 to 10It works now!
Is there some sort of step-by-step beginner's guide or something?
