D510MO
- BigJohnT
- Thank you received: 1175
09 Jun 2011 11:41 #10389
by BigJohnT
D510MO was created by BigJohnT
I have a couple of D510MO's and right out of the box I get just under 10,000us latency which is good. After following some conversations on these I decided to see if I could improve on that. I pressed F2 at boot up and turned off hyperthreading and got the latency down to 7,800us... not bad.
- piasdom
- Thank you received: 10
09 Jun 2011 12:28 #10390
by piasdom
Replied by piasdom on topic Re:D510MO
Very good. that seems to be the hardest thing(for me) in emc to
accomplish. i get about 32,000. Congrats !
- PKM
- Thank you received: 3
09 Jun 2011 12:57 #10392
by PKM
Replied by PKM on topic Re:D510MO
Jonh, is it with or w/o isolcpus ?
- BigJohnT
09 Jun 2011 16:14 - 09 Jun 2011 16:14 #10393
by BigJohnT
Replied by BigJohnT on topic Re:D510MO
That is without isolcpu, I did find this on the wiki site about grub2 and 10.04.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?The..._Parameter_And_GRUB2
and plan on trying that next just to see if it gains me anything.
And after running the latency test about 6 hours the max latency is 8,835.
Last edit: 09 Jun 2011 16:14 by BigJohnT.
- step4linux
- Thank you received: 5
10 Jun 2011 06:55 - 10 Jun 2011 07:00 #10403
by step4linux
Replied by step4linux on topic Re:D510MO
isolcpu should bring another improvement.
I have been running 2.4.6 on a foxconn dual atom board for a while with HT off and isolcpu 1.
I think there was never jitter well above 3 usec. EDIT: correction 5 usec
It might be I have not stressed it too much, only firefox.
Gerd
Gerd
Last edit: 10 Jun 2011 07:00 by step4linux.
- BigJohnT
10 Jun 2011 11:25 - 10 Jun 2011 11:28 #10406
by BigJohnT
After 24 hours of running the latency test it was up to 9400us. I've just did the isolcpu as shown on the wiki so we will see what that does.
Right off the start the latency is 5270us... we will see what we get after running a while.
Last edit: 10 Jun 2011 11:28 by BigJohnT.
- step4linux
10 Jun 2011 13:45 #10408
by step4linux
Right off the start I was at 3 us, now after some hours I'm at 7.204.
I have a joypad connected by USB, and did also some files copying back and forth to a USB stick.
Used also firefox, every now and then.
What is your test bench, John ?
Gerd
Gerd
- BigJohnT
10 Jun 2011 14:35 - 10 Jun 2011 14:35 #10410
by BigJohnT
step4linux wrote:
Gerd,
I don't understand your question...
Gerd
Gerd,
Last edit: 10 Jun 2011 14:35 by BigJohnT.
- step4linux
10 Jun 2011 15:08 #10411
by step4linux
I mean, how do you stress your computer, run additional software, attach additional devices, or anything else to force worst case latency
- BigJohnT
10 Jun 2011 16:16 #10412
by BigJohnT
I don't do anything specific, just open a few things up... seems like over time you get a worse latency than if you actually do something.
Time to create page: 0.093 seconds
