D510MO
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
19 Aug 2011 20:27 #12629 by BigJohnT
Replied by BigJohnT on topic Re:D510MO
My guess is that if the CD works on both ports and after repeated boots that the issue is with the hard drive.
  • schmidtmotorworks
  • Elite Member
  • Elite Member
19 Aug 2011 20:57 #12630 by schmidtmotorworks
Replied by schmidtmotorworks on topic Re:D510MO
Sounds logical, I'll try to pick up another drive on the way home
  • schmidtmotorworks
  • Elite Member
  • Elite Member
20 Aug 2011 18:36 #12635 by schmidtmotorworks
BigJohnT, way to go good diagnosis!
I replaced the Solid State Drive and it worked :cheer:
I also found some other people had a similar problem with that drive.
Now onward and upward to HAL and Wiring.
Thanks everyone for you help on that, it can be very nerve racking when something that you expect to take minutes to do seems impossible.
  • BigJohnT
  • Administrator
  • Administrator
20 Aug 2011 18:47 #12636 by BigJohnT
I'm just glad you got it working and can move on...
17 Sep 2011 06:46 #13227 by RayJr
Replied by RayJr on topic Re:D510MO
I have been following this thread and decided to try out one of these boards.
I got the intel 4GB internal usb flash drive.
I was having problems getting it to boot after installation.
I found that the BIOS needed to be updated (board had vers. 0400, current vers. 542)
Lesson learned: Don;t assume that a new part has all of the latest patches for proper operation!
I hope this is an aid to others thinking of trying this motherboard.
RayM
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
  • BigJohnT
  • Administrator
  • Administrator
17 Sep 2011 11:40 #13231 by BigJohnT
What did you have to do to update the bios?
17 Sep 2011 16:09 #13233 by RayJr
Go to the Intel site www.intel.com
select support from the menu
select "Desktop boards, Intel NM10 chipset family boards, Intel D510MO
that should get you to the downloads page for this motherboard.
select the BIOS downloads. that will show three options. I downloaded the zip file.
On that page you can select the release notes to look through what has been fixed since version 0400
I made a DOS bootable USB stick then unziped the files to that (move the files to the root directory of the USB)
Boot from the stick, then run the iflash2 utility: iflash2 /p MO0542p.bio
It takes about a minute to run. DO NOT POWER DOWN WHILE UPDATE IS IN PROGRESS the system will reboot a couple of times during the process.
This update fixed three issues I was having with installing and running from USB media, plus the system seems more stable.
Ray
Albert Einstein
  • BigJohnT
  • Administrator
  • Administrator
17 Sep 2011 21:38 #13234 by BigJohnT
Thanks Ray
21 Dec 2012 10:33 #27911 by Tilman
Replied by Tilman on topic D510MO
Got the chance to get a D510MO for a bargain and since my old IBM ThinkCentre doesn't have the best latency times, I thought it's time for a change. Unfortunately I have some strange realtime problems with the board and can't find the reason.
Worst case max jitter is up to 8000ns when I connect USB devices like a stick. My TripleBeast controller runs with the following values:
Step time: 2000ns
Step space: 2000ns
Dir. hold: 2000ns
Dir. setup: 2000ns
I thought I'd be on the very safe side with a base period of 20000 but while testing today I've got a few times the message "Unexpected realtime delay; check dmesg for details". Also it happened a few times that there was only a black screen with the cursor left, when I closed Axis. In some cases I was able to properly shut down the computer by power switch, in other cases the system freezed completely. I increased the base period now up to 35000 but the problem remains.
My system:
- PCI LPT card with Moschip MCS9865
- 160GB WD 2.5" HDD
- 2GB Ram
- PS/2 industrial keyboard with trackball
- Logitech game controller
- fresh Ubuntu 10.04 installation from a live cd, with all recommended updates
Any ideas what to do? I let the latency test run 2 times over night but there are no spikes at all.
21 Dec 2012 15:31 #27916 by ArcEye
Replied by ArcEye on topic D510MO
What was in dmesg?
Run linuxcnc until you get the message, close it and immediately copy /var/logs/dmesg somewhere else and zip it and attach.
Time to create page: 0.109 seconds
